Question about Car Audio & Video
My xt 4000D amp will not play the blue power light is on what could be the cause.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 123 Answers
Ground wire loose, and make sure your constant 12v fromm the battery, and last but not least your on and off remote wire coming from the head unit, it turns the amp only when stereo is on.. if all those wires check out then your RCA cables got cut or mangle, make sure your speaker wires are connected right , the woofer should blow outwards no inward, if inward your negative and pos canles are backwards.
Posted on Dec 17, 2016
Yamaha xt 125 rear brake light not working
Hi, Anonymous before diagnosing any brake light issue always check the bulb and fuse first for integrity a brake light staying on is usually caused by the front brake light switch, which is mechanical, not disengaging. On early models moving the throttle control housing closer to the front brake master cylinder is the main fix. On late models, the switch gets tweaked and needs to be realigned. A brake light that does not come on when the brake lever is applied can be caused by a faulty switch or no continuity in the wiring at the switch. The rear brake light switch is hydraulic and it is extremely rare to malfunction in a closed circuit condition causing the brake light to stay on. Usually, rear brake light switch issues are caused by no brake pedal free play or a sticky rear master cylinder piston. A brake light that does not come on when the rear brake pedal is depressed can be caused by a faulty switch, air contamination in the brake line, or no continuity in the wiring at the switch. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha xt 125 service manual
OEM parts for Yamaha
Aug 26, 2012 | 2006 Yamaha XT 125 R
My truck keeps blowing fuses in my power wire like its grounded out. i have re-done everything and it still does the same thing
It may not be the wiring, it could be the amp itself. If you are completely confident the power wire is not grounded the following test will confirm it. If it is grounded you will be out another fuse. Disconnect the power wire from the amp. Tape or cap off so it doesn't accidentally touch metal. Replace your fuse (take a part the fuse holder if you can and use a small cheap fuse.) If it is grounded the fuse will pop. If it doesn't pop, the problem is in the amp or improper wiring at the amp.
Apr 25, 2011 | DHD US Amps Xterminator XT-4000D
Wanting to wire 2 dual 4ohm speakers to the amp do i use 1 channel or both?
Hi, the amp is stable down to 1 ohm per channel, so use both channels--one per speaker.
Feb 27, 2011 | DHD US Amps Xterminator XT-4000D
I cannot get my brother 4000d threaded correctly
on the website,, they have downloadable manuals,,,on the home page go to product manuals
& then select home sewing & embroidery & then look for the model number of the machine
Dec 08, 2010 | Brother InnovIs 4000D Computerized Sewing...
The protection light wont go off when hook it up
Remove off the speaker and check if the protection light changes, if so the speakers are short by themselves or to the body.correcct and check.
However if there is still no difference then the amplifier output is short. you will need to check for short in one of the stages and change.
Aug 27, 2010 | Power Acoustik PS1-4000D Car Amp
Amp has no sound?
Yeah, u are probably right. If u are good enough with electronics it is a pretty easy fix
Feb 07, 2010 | Power Acoustik OVN1-4000D Car Amp
Need to pick perfect amp
I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
Here are my Top 5
  • Lanzar -OPTI4000D
  • MA Audio- HK-4000D
  • JL Audio 1000/1V2
  • OPti 22.2 Power Amp
  • AudioBahn-A5100T
Apr 05, 2009 | Power Acoustik FUBAR-12W Car Subwoofer
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
