Question about Dyson Vacuums
My Dyson Max is no5 charging, yellow light is on not green.
Dyson v6 surges on and off
Hello, this is Ava with Think Crucial.
There are a number of things you need to do that may solve the issue you're having with your vacuum. First, make sure that your battery is charging and working. Second, check the MAX button. If the MAX button lights up and flashes when your Dyson cordless vacuum keeps pulsating on and off, hold the power button and depress the MAX button to turn off that function. You may have to try a few times to get the hang of it. And lastly, look for any blockages in attachments because the pulsating is caused by a lack of airflow as the motor is protecting itself by pulsating and then ultimately cutting out.
You can check this video tutorial which will teach you on how you may fix it:
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 18, 2016 | Dyson V6 Motorhead Bagless Cordless Stick...
I have had my dyson dc59 for about 3 months. Wheni try to turn it on by the trigger it won't start. I know it has a full charge so with my messing around with it i pressed the max button and it turned...
Hi Jeff, it's Jack at Dyson.
The issue you're describing with your DC59 sounds very unusual, but I'm sure we can help. Like all Dyson cordless and handheld vacuums, DC59 is backed with our 2-year Dyson parts and labour guarantee.
When you have your machine fully charged and easily to hand, please give us a call so we can talk you through some simple diagnostic checks. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Feb 23, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
Max is on
Hi there, it's Jack at Dyson.
From what you've described, it sounds as if the battery may not be charged. If your machine has been allowed to recharge for over 5.5 hours but still has no power, there may be an issue with the battery or the charger. However in order to confirm this, and to help resolve the issue, we'd need to take you through some further diagnostic checks over the phone when you have the machine to hand.
When you have a moment, please give the Dyson Customer Helpline a call - you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 03, 2014 | Dyson DC44 Animal Handheld Vacuum Cleaner
Dyson dc31 won't charge
Sounds like the charger is bad. It is 24vdc output, so you can check with a voltmeter. It probably blew the fuse inside since it isn't lighting the green charge light. There are replacement chargers for this for under $20.
Dec 04, 2013 | Vacuums
Flashing charging lights when on charger.
smething internal is burnt out possible bad battery.
Nov 29, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Vacuums Logo
32 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
