Question about Tablets & eReaders
Tried to update yesterday. App is frozen. Also using 1.02 GB of space!
My candy crush game will not open on my IPad 2? Can you tell me what I need to do! I've deleted the app and the restarted. I've logged off of Facebook. I've got space. The game opens on my phone.
Candy crush issue is mainly because of updated version of IOS on ipads ... update your ios on ipad and re-download the game. it will work properly..
Oct 06, 2016 | Apple iPad 32 GB WiFi Tablet PC
Facebook frozen after update
Uninstall the APP on the iPad and then reinstall it. If this doesn't work, I would suggest restoring the iPad. Connect it to iTunes and restore it. Or you could do it from he iPad itself.
Sep 04, 2016 | Apple iPad 32 GB 3G Tablet PC
How can I find an old Hulu app?
Hi Deborah,
Hulu on the App Store
The link above will take you to the app in iTunes or App Store. If you receive an error stating you cannot download because you need to update, that may be your only option. By the model listed above I'm thinking your tablet is very new so you should have little trouble updating your iPad.
I will leave a link below describing how to update your iPad (link takes you to Apple Help).
Update the iOS software on your iPhone iPad and iPod touch
I hope this find you well,
Niall
Nov 19, 2015 | Apple iPad Air 9.7" 16 GB Wi-Fi Space Gray...
Cant get into kurio app store it keeps saying it needs an update but when I do the update it says storage space is running out and wont do the update
Not sure about your tablet, but generally if you delete an app or two and delete any cache that is stored you will be amazed how much space is freed up along with the benefit of it running faster.
Jul 21, 2015 | Kurio 7S Tablet
How do I fix my seem to be frozen Facebook app, everything else works perfect can you help me?
At first, u r activating "Don't disturb" mode. U need to disable it from control center (icon with half moon) or from the setting ( Don't disturb mode). if it didn't work after that, please reinstall Facebook app again after deleting it.good luck
Feb 12, 2015 | Apple iPad 32 GB 3G Tablet PC
Nobis 9 8 gb will not let me add games. says it has no more space
You might need to install an sd card they range from 2 to 32 gb and are available most anywhere. If there is already an sd card installed you might need to move everything to a larger sd card with your computer.
Dec 26, 2014 | DOUBLE POWER TECHNOLOGY Nobis NB09 9" 8 GB...
How to download gAMES AT PLAY STORE KEEP SAYING ERROR NO MEMORY BUT I HAVE SPACE ON THE Tablet
The Nobis NB09 Tablet simply has too little space partitioned for apps. It has only about 660 MB available. Just downloading and installing the updates for the native apps from the Store will result in the partition being filled to about 550 MB. This leaves only about 100 MB left for apps you want to add.
Click on *Settings* then click on *Storage* The top bar graph is your app partition. It will probably show as about 660 MB and the green bar is how full it is. It wouldn't surprise me if your green bar was at or near the right hand side meaning a full tank.
The second bar graph is your total built-in SD card memory. It's supposed to be 8 GB but it's shows about 5.5 GB. It looks like a lot of empty space but none of this can be used to download apps. From time to time to time there will be an app you run across that will be able to install on the external microSD card you can push into the slot on the back. And one or two of the native apps might be able to be moved to this external microSD card. But, you STILL have too little room to add extra apps.
Nobis simply didn't allocate enough space for app installation and you are stuck with the native apps plus maybe three large or six to eight smaller apps before the internal app space is FULL.
Just feel lucky that what little app memory you have still works. Mine went bad after less than two months and it remembers NOTHING. Every time I turn it off it boots into the set-up mode and retains no changes I made prior. It will not download a thing from the store because the app partition reads in the bar graph 0.00B available. IOW, bad memory. I am currently trying to get a response from the Midland website that took over Nobis and they claim they will reply within 48 hours. It's been two days and no reply so far. There is a phone number listed to call for a RMA (return merchandise authorization) I might have call it if they don't reply to the email.
Basically the NobisNBO9 is junk. Do a little Googling and many many people have problems such as it not booting up - I feel this is all to do with memory gone bad. Cheap Chinese memory - not reliable enough to last more than a month or two.
Oct 05, 2014 | DOUBLE POWER TECHNOLOGY Nobis NB09BLUE 9"...
Facebook login problems
Have you tried to hard reset the device? To do this just press and hold the power and home button and the same time until you see the screen go black and the apple logo appear , now let go of both buttons, allow the tablet to start up. Try the facebook app again, does the problem persist? If the problem still persists, check to see how much space you have on the tablet, sometimes the limited amount of space on the device can prevent an app from functioning correctly. If you find there is not very much space remove several items, to create more storage space, then attempt to use the Facebook app again, does the problem still persist? If so, check the App Store to see if there is an update for the facebook app, if you find one under updates, install it, try to run the App again. I hope something here has helped you resolve your issue.
Sep 02, 2014 | Apple iPad 32 GB WiFi Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
