Question about Kenmore Washing Machines
My Kenmore -HE W10280502A (0610) Will not start. It feels like the Lid Lock is not working.
  • Kenmore Master
  • 5,323 Answers
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
God is good and that's why I give free advice.
Washing Machine Repair Help
Posted on Jan 05, 2017
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite oasis 27082 - lid won't lock
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
Jan 08, 2016 | Kenmore Washing Machines
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Kenmore 2800*010 will not fill
It sounds like you have a bad lid switch. There is a tech sheet taped to the inside of the front of the cabinet. The part # is w10404050, made by whirlpool.
May 03, 2014 | Kenmore Washing Machines
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
P/n w10280537A (0610)
bought Kenmore washer oct 25 2011,2 days ago started shaking and now drum is loosened,and loud noise. Now what?
Dec 30, 2011 | Kenmore Washing Machines
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
83 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
