Question about KitchenAid Kitchen Appliances - Others
My Kitchenaid fettuccine cutter does not completely cut the pasta. I have to separate by hand? Any suggestions? They are only sold as a set (3) and I don't need the others.
5 Suggested Answers
  • 905 Answers
SOURCE: KitchenAid KP2671 - Spaghetti cutters stopped turning. Makes loud noise.
this is common for any device that has a motor,either the gears are grinding or the motors contact brushes need replacing, it will have to be looked at to determine the exact cause
Posted on Oct 13, 2008
  • 53 Answers
SOURCE: How do you use the KitchenAid SNFGA Pasta Maker Attachment
If it's gumming up, the dough is too wet and needs to be dried out more by adding flour. The right consistency dough is such that if you tear off a small piece and then tear it in half and squeeze it back together with your fingers it should stick back together but not stay stuck to your fingers. If it stays stuck to your fingers it's too wet and needs more flour. If it is crumbly, it's too dry and needs more water.
Posted on May 31, 2010
  • 44 Answers
SOURCE: What is fettuccine pasta? How does it look?
Fettuccine pasta is nearly always found on restaurant menus as one of the choices. It's basically ribbons of pasta that are about half a centimeter wide and cut into little strips.
Posted on Feb 20, 2013
  • 43969 Answers
SOURCE: Need disc "XM28X121" cutter holder for GE food processor D5FP1 (old)
Check with an appliance parts supplier.
Posted on Jan 08, 2015
Broken input shaft
KitchenAid doesn't sell any internal parts for the KitchenAid pasta attachments, the only thing to do is buy a replacement, if it is just the pasta roller you can purchase the KPSA, if not the others are just sold in the KPRA pack
Mar 07, 2014 | KitchenAid Kitchen Aid KPRA Pasta Sheet...
My Marcato linguine cutter attachment is not cutting through. Can I adjust this?
These are notorious for the issue! If you can find a machine shop or maybe someone that repairs machines, such as a sewing machine, they may be able to adjust it. It just cannot be done by a regular unskilled person. Good Luck!
Nov 02, 2013 | KitchenAid Pasta Roller / Cutter Set
What is Tagliatelle pasta? They always offer it at our local Italian restaurant and I am too embarrassed to say that I have no idea what it is.
Tagliatelle is a pasta that is ribbon shaped just like Fettuccine, but it's cut a lot thinner. In Italian, Tagliatelle means 'little cut ones'.
Feb 20, 2013 | Cooking
Kitchenaid pasta roller
The others had good solutions but I thought I would add mine as well.
I put vegetable oil on both outer edges of a folded paper towel that fits the entire width in the narrower roller settings of the machine. I run it through 3-4 times as if it were a piece of dough. It takes away the squeaking.....at least until it is needed again.
Feb 12, 2013 | KitchenAid Pasta Roller / Cutter Set
Where can i get gears for kitchenaid pasta roller
Not a solution, just want to echo the problem. There are solutions for the shaft, but when I opened this up I found a stripped nylon gear attached to the shaft. Kinda sucks: I recently replaced the nylon worm gear in the mixer, now I have to do the same in the spaghetti cutter. I can't find the part or any mention of it anywhere.
Jan 17, 2013 | KitchenAid Pasta Roller / Cutter Set
When cutting noodles they are coming out two noodles together? why?
Your blades are not completely set in their tension. You may have to replace the blades.
Nov 24, 2012 | KitchenAid Pasta Roller & Cutter Set...
Kitchen Appliances - Others Logo
50 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
