Question about Miele Dishwashers
Hi, i have a old Miele washmashine, W409SB starting and go direkt to pumping out water all time! not stopp whith draining out water, electronik problem??
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
joe_lishman
  • 192 Answers
SOURCE: Inlet/drain light flashes on miele dishwasher and
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Posted on Jan 17, 2010
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
Daniel S
  • 4323 Answers
SOURCE: Miele Optima G 2430 -
Hi
The first thing that should be checked is if its draining properly as it could be that the drain hose is clogged and needs to be cleaned. The drain pump also should not be clogged. Also the stopcock should be opened fully and the water inlet valve should be checked for any clogs. Also the metal filter, impeller cover and the air gap unit should be checked. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 14, 2011
SOURCE: Hi, my Miele G1142SC makes noise at startup
Mine is doing the same thing. I tried running a finish cleaner though a cycle. I did nothing I was about to do the same thing again when it just stopped doing it. What did you end up doing?
Posted on Feb 20, 2011
What could be wrong with my Miele Novotronic premier 500 If I use the drain/spin the machine makes a grinding noise which I~ don't hear when I use the washing programme
hi my guess is that as the machine is on drain & spin that is the time when the pump which drain the water is turning to empty the water and hence it also on when on spin to get rid of the water .
I think you may have a foreign body in the impeller of the pump , ( paper clip , a pin needle etc., ) usually by removing the filter which is located by the pump you will find foreign body in the filter but sometime these clips /needles / nails they get imbedded in the pump housing with long nose pliers they will pull out , but be careful not to puncture the pump housing
Nov 24, 2017 | Miele Washing Machines
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Dishwasher not draining
you need to remove the drain pump motor and see what is obstructing the impellar.(small shreds of glass:small popcorn pieces etc. Doesnt take much to stop the drain pump.Try and get to drain pump from the front. Miele very compact.
May 28, 2010 | Miele Incognito G818SCVi Built-in...
Have Miele G653 SCVi plus. We have inlet/drain flashing red light
Sounds like something is caught in th drain pump as the unit has to drain first before anything else happens. Remove the filter and the non return valve which is under the clip in the sump of the unit. In the manual it shows you this. Make sure the drain pump is free of any foreign particles like broken glass. Then start the unit again so it goes to drain without the non return valve in place. This will then throw out any foreign particles as well.
or it could be the drain pump is activated all the time which is the noise you hear as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Feb 22, 2010 | Miele 24 in. G653 SCVi Plus Built-In...
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
In the user manual there's a section on how to clean the non-return valve. It's the plastic piece under the wire below the triple filter. Why did you pull out the machine? Did you kink the drain hose? If you don't find a clogged valve, spin the impeller wheel several times. It's under the valve inside the bottom hole where the valve came out.
Now here's the important step- Reset the fault! Power off/on the unit. If the light blinks when you turn it on, Press and hold the start button 4 seconds with the door open. Find the combination of off/on buttons to press to reset the machine in the user manual.
(Note: If the machine runs continuously as soon as you pressed on the power button, then you have water under the unit in the safety pan. Call Miele for help.) Now select the normal wash cycle close the door and start it. The drain motor always runs first. This verifies to the brain how much water is inside the machine when it starts filling. The drain pump runs for half a minute. If you hear it running with no drain check the drain hose especially if it's connected to a disposal. Clean the disposal.. If it's not running at all the light will go on again before filling, call Miele. If the machine fill up with fresh water, the drain works. Watch and listen when the light comes on. Is it filling or did it start circulating? Open the door, are the baskets are dripping wet? Then it filled and circulated. If the light comes on several miutes later then call Miele.
Feb 04, 2008 | Miele 23 in. Novotronic G841 Built-In...
Dishwasher will not start
Check the drain pan area under the dishwasher, if it full of water it will trip a float switch and run the drain pump until the water evaporates or is removed by a shop vac.
Oct 03, 2006 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
