Question about Fujitsu Heating & Cooling
Fujitsu thermostat My fujitsu Halcyon inverter works fine unless I have a power failure. When that happens the unit reverts back to factory setting and allows the air handlers to detect room temperature. This is bad because one is in the attic and one in the basement. With the attic reaching high temps in summer and cold temps in winter the unit works overtime to try to reach an unreachable temp. Summer making the rooms too cold and winter too hot. Not good if you are not home. Fujitsu has not been helpful and claim only their thermostat will work with the unit. This is obviously a defect. I can change the thermo back to detect room temp, but what happens when I'm not home. A battery backup might work or is there a thermostat that will hold the settings after a power failure.
4 Suggested Answers
  • 44 Answers
SOURCE: adjusting thermostat temperature
nope. Try bouncing the air off the ceiling instead of pointing it towards the floor. You know the vent grille should be adjustable. The air is just recirculating back into unit and short cycling stat. Create a barrier between supply and return!
Posted on May 28, 2009
  • 45 Answers
SOURCE: Fujitsu fujitsu ast24bbj not heating
faulty reversing vavle.get a quilfied a/c tech to come a look at the reversing vavle.and tell him to replace the compressor when he does a quilfied a/c tech and i have done heaps of fujitsu and thay are common for this problem.
Posted on Jun 09, 2009
  • 2133 Answers
SOURCE: We have an Art Series
Remove battery from your remote. After 10 seconds, again reset it. Now you can set as per your wish..
Is it helpful?
Posted on Dec 17, 2010
Fujitsu aou30clx compressor location detection error
You must turn off of the power for 10 minutes. Then open the front of the indoor unit and push the emergency button for 10 seconds. The compressor will unlocked.
Apr 18, 2013 | Fujitsu 30CLX HALCYON Wall Mounted Mini...
What error is causing it to flash 2 x green and red then 5 x red?
This fault relates to a over current protection,
fault can be a number of things
connection failure (check power and connections)
outdoor fan failure (fan operating?)
outdoor coil dirty (is air passing through coil or is it clogged)
compressor failure (compressor operating?)
pcb and/or inverter PCB failure (is there power at boards or any visual damage)
Aug 14, 2012 | Fujitsu ASU36CLX1 HALCYON Mini Split Wall...
Fujitsu halcyon economy light and operation light flashing
I have a fujitsu DC inverter model no. ASYG18LFCA not a week old as yet, when I turn it on it works fine for 5mins. then stops and after a short time the timer and economy lights start flashing, can anyone help on this, please.
Apr 02, 2012 | Heating & Cooling
How to use thermostat for heat on Fujitsu IAQ halcyon
This unit comes with a remote control (optional wall mounted wired thermostat available) as a standard feature. This unit is precharged with the environment friendly R-410a refrigerant. No additional refrigerant is needed if the line set is 49 feet in lenght or shorter. In addition to its very high 20 SEER efficiency rating, the 15RLQ is only 31 in. long which makes it the smallest Mini-Split System in its category through out the industry.
This category of equipment is ideal for smaller spaces where spot cooling is required. Several models in this category are ENERGY STAR Certified, meaning they save you money on your utility bill. Residential applications including sunrooms and additions are made easier with these air conditioners and heat pumps. Do you have a warm spot in your home? Fujitsu mini-splits can provide extra cooling capacity for those hard to cool areas. Commercially, their small size makes them ideal for small offices, providing individual temperature control.
Fujitsu's I.A.Q. Systems provide residential and commercial property owners an innovative solution for clean, temperature-controlled indoor air. The Halcyon IAQ systems deliver powerful heating and cooling, are designed for ease of use and maintenance, and feature an unobtrusive design which can be integrated easily into any decor. The Halcyon IAQ systems filter dust, pollen and odor making them the perfect addition to any home!
  • Wireless Remote Control
  • Plasma Filter
  • Sleep Timer
  • 24 Hour Timer
  • Dry Mode
  • Auto Louver: Up/Down
  • Auto Mode
  • Quiet Mode
  • Auto Restart/Rest
  • Auto Changeover
  • Low Ambient
  • Cold Prevention
Warranty All Fujitsu ductless mini-split air conditioners and heat pumps come with a 2 year parts and 6 year compressor warranty.
Important: All installations must be performed or supervised by a certified HVAC technician in order for the warranty to be valid.
Dec 08, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
