Question about Coleman Heating & Cooling
I have Coleman Heat pump and i want it to conect as AC only any ideas since i changed furnace to gas and the guys dont know how to conect it back as AC only.
  • 3,361 Answers
Change out the thermostat to a straight cool gas furnace stat.If the reversing valve energizes in cool, simply hook the reversing valve low voltage wire to the yellow compressor wire. If it energizes in heat do not hook it up to anything.
Posted on Jul 20, 2009
Coleman/ Evcon central electric furnace Eb15b thermostat on auto will not blow air out i hear a click u see and feel it heating up then i hear Another click dont see nor feel heat then but put thermostat...
check the thermostat setting on back for electric heat. sounds like it is on gas heat. the fan should turn on right away if it is electric or heat pump.
Nov 15, 2014 | Heating & Cooling
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
True air heat tries to start then goes to gas.It worked fine in the fall but it is now -5F
Do you have a heat pump and gas furnace setup? Or is it electric and gas setup.
To me it sounds like either configuration issue its electric and gas, but if its heat pump/gas the furnace is defaulting to gas more then likely on the outside air temperature, usually most heat pumps only heat good down to 10 degrees F.
Nov 18, 2013 | Coleman Heating & Cooling
I have a coleman evcon gas furnace that keeps giving me an error code (Limit switch open, and sometimes it wont kick on when i get this code, I have replaced the Lower Limit Switch, and workd fine for a...
i hope the heater doesnt come on when a limit switch is open,you really have problems. so a limit is telling you that your furnace it over heating. first check filter and heat vents and returns they must be clean and open. closing heat vent or blocked returns will cause over heating. after chacking this look at firing rate. furnace could be overfired. you would need a "u" gauge to check manifold pressure. your name plate will tell you what this should be. find the tap on the burner manifold or outlet of gas valve. fire furnace and see what it is. 3.5"wc for nat and 10" wc for propane maybe.
Feb 10, 2011 | Coleman Propane Forced Air Heater...
I have a suburban lp furnace and duotherm air/heat pump roof unit. duothern thermostat. 20 amp breaker kicked ( reset breaker) & furnace quit. NOW furnace fan comes on but does not light, and the front...
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 23, 2010 | Dometic Rooftop RV Air Conditioner
I have a 15 year old Coleman Propane 130,000 Btu force air furnace, Model #BGU13020 forced air furnace. Afer the unit runs for 5 to 10 minuets, the flame will start to shuter and then it will trip the heat...
DO NOT attempt to repair this yourself. LP gas is a very unforgiving gas. Sounds like your heat exchanger is plugged. Yes it can be removed and checked, BUT it is not recommended. Trust your local repair tech. Any heater 15+ years old should be discarded.
Dec 26, 2008 | Coleman Propane Forced Air Heater...
Problem with heat pump
This sounds like a 4--step furnace. Step 1 ,the small ven fan turns on and proves it turnning thru the small air tube that sucks a switch close . Step 2 the spark igniter lights the pilot ...Step 3, the main gas valve opens up and dump gas in the venture tubes to heat the box up, Step 4 theres a swith in the box the when heated closes and turn the fan on! Thank-you-very-much!
Aug 18, 2008 | Coleman Mach III Air Conditioner
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
95 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
