Question about Tablets & eReaders
How do i download viedos from my nook to sd card
My daughter-in-lase STEPPED ON my granddaughter's Nook!!!!! Now, although the screen is not broken, there's nothing but lines all over the display. Is there any hope of saving it?
The device cannot be fixed.
Your information is another matter. Any book, music or app you bought will still exist in the account. Also, ANYTHING sent to the cloud will still be there.
All else you put on your Nook is gone unless there is a copy on a PC where it was originally.
If anything was transferred to a SD card, it is still there.
Mar 10, 2017 | Barnes & Noble Nook Tablet
Have downloaded e-books from the library, but can't delete them from my Nook.
For some books, downloaded from your PC, the only way to delete them is to attach the Nook Simple Touch to your PC and open the Nook Simple Touch on the PC. (For a PC, open the computer icon and look for the Nook icon and click on that.) From your PC you can delete files from the Nook Simple Touch or move them off the Nook Simple Touch to your PC.
IF you have a MAC or if my advice doesn't work, you should contact the Nook support. It is at the Nook website. Click on Nook and look for Nook support.
Jul 30, 2015 | Barnes & Noble NOOK Simple Touch eReader -...
How do I download a book to nook to my micro sdhc storage disc?
connect to your computer and d/l to there,then put it on the sd card
May 31, 2015 | Nook HD+
Shows 99% won't open and can't shut down
You can first try doing what's called doing a Soft Reset. It's the first and preferred method to try as you don't lose any files or settings. Hold the power button until the Nook turns itself off. In most cases that will be twenty seconds or more. Then turn the power back on by holding the power button down for about two seconds. Hopefully this will allow you to complete a normal boot process. The second and more dramatic way to get a working Nook back is what's called doing a Hard Reset. This process will put your Nook back to "Just Out of the Box" mode. You will lose any files and settings stored internally inside the Nook itself. The good part in all this is it won't touch anything stored externally on your external SD Cards. To do a Hard Reset Turn the NOOK off completely. Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. ------- The important part in the above is to be sure you start the Nook via holding down both the power button and the Home (n) buttons at the very same time and keep them both pressed down until the Nook turns itself off.
Mar 07, 2015 | Nook HD+
Why my nook tablet will not turn on ?
If the screen is off and won't turn on, make sure the battery has a charge. Plug in your device for 30 minutes before trying anything else. If it is on or if the battery has a charge you may need to "hard reset" the Nook. Although this is very uncommon, it may happen. Below are a few solutions that may help.
  • Hold down the power button for 10-15 seconds. The Nook should power off and you can turn it back on again. Everything should work normally.
  • If that does not work you will need to hold down the power button and the "N" button for 10 or more seconds. Again, this should force your device to power off and you can start it up normally.
  • Take out the N2A Card and try the same steps again. Your Nook should boot up into Nook mode. You'll have to restart it again with the N2A Card in to boot up in Android mode.
One of the tasks above will usually correct this issue unless you have a hardware problem with the Nook. Our cards cannot cause hardware problems unless they are forcefully inserted wrong. If you determine you do have a hardware problem you will need to take the Nook back to the retailer if it is still under warranty. The Nook usually comes with a one-year (non-accidental) warranty through Barnes & Noble. Some retailers, like Best Buy, exchange them in the store under warranty.
Don't forget to hold onto your N2A Card until they return your Nook!
If you still have any kind of issue thenhttp://www.tablethelpline.com/nook-support/ you can take Nook Help from experts by calling nook customer service number.
May 16, 2014 | Barnes & Noble nook color eBook Reader
Unbricking a nook tablet
Well i fixed my nook like that simple, If you mean its gonna reset just re-input your past data and it'll be all right! If not u need to goto the store or ask for help from an expert.
Feb 24, 2014 | Barnes & Noble Nook Tablet
Reset nook
I think the phrase you are asking about is not "Reset" but rather "Root"
Root is the process of removing the restrictions from software. In this case, the Nook Tablet was designed with the Android OS, and then Barnes and Noble added their "software" on top of it, setting restrictions to the Android OS. an example would be, unable to visit the website Amazon.
Search the forums for XDA Developers as they are constantly updating their information. I have successfully "rooted" my Nook Tablet using an SD Card approach, and have had access to all the features of the internet as well as Google Play store.
Only reason I did it, my wife's games; Temple Run ($15 B&N, $1.99 GPlay)
Best Solution, sell it or return it, if possible, buy a Android only Tablet (Nexus, ASUS, Polaroid, Samsung, etc..)
May 13, 2013 | Barnes & Noble Nook Tablet
My Nook Library has disappeared on my Nook-how do I restore it?
Download all the archived and unarchived books and save them to your computer. Never deleted these.
You have two options for the archived books.
Un-archive them and they will appear on your nook and download as you see fit.
OR... Sideload them. Which is probably what you did before since archived books already disappear from your My B&N Library and would have had to be in your My Documents Library.
Not exactly sure what you mean by 'does not go to my nook' when you try and save/download from the website.
If still having any kind of issue then you can take nook support from experts or call nook help number.
Mar 24, 2013 | Barnes & Noble nook color eBook Reader
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
