Question about Car Audio & Video
The cd player in my 2000 toyota 4runner skips on a regular basis....like every 2 1/2 minutes of play time....what causes this and can it be fixed...
My Cd player light don't work for what ever reason,night driving and ply with the Cd is very hard please help ?
Posted on Aug 25, 2009
Repairing coby cx-cd118 cd player
hi there.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. ... If theCD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
How to Fix a CD Player That Skips ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
cd player skips Google Search
Nov 27, 2017 | Coby Lands Phones
ALL DISKS SKIP ON MY SONY CDP - CX53...SOLUTION?
If you have access to the lased head, gently wipe the lens with a stick with cotton moistened with isopropyl alcohol, or regular sanitary alcohol. Use circular movement. Then, gently shine the lens with dry cotton. DO NOT PRESS THE LENS !!!! If the issue persists, it's more complicated. You need to have access to the tiny trimmer below or near the laser head. Using a plastic screwdriver, rotate the trimmer clockwise about 2-3 degrees. Test playing. If track doesn't skip, hit the CD player's case with the finger, to check if track skips because of shock. If skips, rotate trimmer again 1-2 degr. Check again. If it doesn't work, try rotating counterclockwise. You need patience. Hope it is useful.
Mar 11, 2015 | Sony Audio Players & Recorders
Skips when playing CD or DVDs
First try a cd head cleaner. It has to work well enough to ffwd to track 4 or as instructed. If that does not work you need to open the case. Unplug power as the laser can blind you. 5 screws on the back and one each side. Lift the lid from the back to about 30 degrees and pull/ wiggle it off. Use a cotton bud wetted with alcohol (Isopropyl or surgical). You need to wipe the glass lens very very gently. wipe dry with other end of cotton bud. Recover and try.
While covers are off look for bulging capacitors or signs of black overheating.
Jan 24, 2013 | Jamo DMR 60 DVD Player/Receiver
2000 Nissan Maxima GXE: CD player issues
The laser assembly has lost its ability to focus on disk surface. Replacement of unit is in order/repair not cost effective.
Jun 20, 2017 | 2000 Nissan Maxima
CD Player Skipping And Spinning Backwards!
Clean laser first. Near the laser there will 2 / 3 adjustable pots. Mark location on them all first. Pick one (then another) move a little left or right and see if you can get it working. If all fails return them to original positions nothing but time lost.
Apr 01, 2017 | Yamaha CDC-502 5-Disc CD Changer
Player 2 skips and plays a different track
May need manual cleaning or Cd Mechanical assembly may need to be replaced
Dec 03, 2008 | Nu Mark Numark Cdn36 Dual CD Player CD...
2006 Toyota 4Runner Sulfur smell
I noticed going from a Higher Grade gasoline as well as making sure I change my motor oil on a regular basis (3,000-5,000 mi)to solve this problem. When the car isn't driven at a high RPM for a while, and you go to a quick acceleration it causes this smell.
Jul 22, 2008 | 2006 Toyota 4Runner
Help
I'm having the same problem. I get an error message for the first cd, but will play ever other cd.
May 17, 2008 | 2003 Toyota 4Runner
Skipping yamaha 765
I have a very similar type unit, a Nakamichi CDC-3 that had the same problem. I found this link....
http://repairfaq.ece.drexel.edu/REPAIR/F_cdfaq6.html#CDFAQ_001
I spent about two hours fixing mine. The sled mechanism was binding somehow, causing random skipping. The first 10 minutes was getting it apart and figuring what was wrong, the remainder was spent getting all those tiny parts back in the proper place.
Look up the exact symptom before going at it (probably long skips). Set aside a long slow lazy day with nothing to do. DO NOT drink too much coffee, you will be handling tiny parts that go in tedious locations, so you don't need caffeine jitters adding to your misery. Take your time and be careful. It's well worth it. Mine plays like a new one.
Nov 26, 2007 | Yamaha CDC-585 5-Disc CD Changer
MP3 files start skipping/popping after few minutes of playback
Sony say in the manual that if you record high bit-rate mp3's the sound may be intermittent. I feel this is due to the decoder having to move ALOT of bits around to play, try some makeing a disk with mixed rate mp3's on. e.g.) some 64Kbps, some 128, some 192, and some as high as you can get and see if there is any differ Luck
Mar 02, 2007 | Sony CDX-MP40 CD Player
Car Audio & Video Logo
124 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
