Question about Armitron Watches
How to turn of hourly beep on a Armitron All Sport 40/8324 watch its really annoying when Im trying to sleep and when I have School
How do you turn off the hourly chime?
Irene, try the link for watch instructions.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Aug 22, 2016 | Armitron 491007rvdg Mens Pro Sport Black...
Stop beeping hour?
According to the directions: Press B - bottom left button,to go into Alarm Mode. Press D - upper right button - to activate the alarm and press again to activate the Chime, which shows on bottom left as a bell. To activate these press D. To DEACTIVATE them press D again. Press B 3 times to return to Time Telling Mode. It took a few tries, but D and B are the keys to stopping that annoying chime!
Oct 18, 2013 | Armitron All Sport Digital watch
The watch is stuck on military time, and it's really annoying. I lost the instructions years ago, and have no idea how to change it. It is an Armitron WR165 All-Sport watch, and the number on the bottom...
go to and you will see a list of illustrations of various watches. Find the one that looks like yours and download the pdf file.
(If there isn't an exact match, choose the nearest- there can only be a limited number of alternative ways of using four buttons!)
Sep 26, 2010 | Watches
How do I turn off the alarm that sounds every hour on my armitron all sport watch?
You can get instructions from the Amitron web site.
Copy "" into your search engine
and you will see a list of illustrations of watches and associated
Choose the one that looks like yours and download the PDF file.
Aug 24, 2010 | JCPenney Armitron Sport Watch
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more :
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
I dont know how to make my armitron watch silent, every hour it beeps to tell me when its 1 oclock 2 3 and so on, but being in school that gets very anoying
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please
Mar 14, 2010 | Armitron Watches
Unable to turn off alarm
You should have a symbol of a bell, which indicates he alarm is "on" and the letters "CH" which means "hourly chime".
Press button at 2 O'clock position to enter the alarm mode. Press the button again and the "bell" should disappear; press the button again and the "CH" should disappear.
Now press the button at the 7 O'clock position to return to the normal timekeeping mode.
Jan 04, 2010 | Armitron 40/8125BLK Digital Sport Watch
Armitron Pro Sport Watch Hourly Chime
Based on insructions for another watch, I just figured this one out. The steps would be:
Get in Alarm mode (press mode button)
Then you can cycle through the following by pressing the ST/STP button
1. Alarm on
2. Chiime on
3. Alarm and Chime on
4. Alarm and Chime off
You can see this with a magnifying glass and watch the center and right hand circular icons at the top of the display.get highlighted.
Dec 26, 2008 | JCPenney Armitron Sport Link Bracelet...
Armitron All-Sport M518, 40/6755
I have the same watch- instructions are hard to find.
Do this: hold the mode button for a few seconds, until the alarm time blinks. Push mode again and the time will blink, then push st/stp to change to minutes or hours, and press adj. to change; press mode when you are all done.
Anyone know how to go from 24 hour (military) time to regular 12 hour am/pm time?
Mar 27, 2008 | Watches
Watches Logo
223 people viewed this question
Top Armitron Watches Experts
Ansel Alberto
Ansel Alberto
Michael Vincent Cruz
Are you an Armitron Watch Expert? Answer questions, earn points and help others
