Question about Elna Sewing Machines
I have an old Elnita 130 sewing machine with no manual. How to I thread it? It appears to work but shows signs that I did not thread it correctly.
Can I get a manual online for Elnita 130. A search keeps changing my request to Elna or different Elnita number.
    Top Expert:
  • Elna Master
  • 51,255 Answers
Elna make elinta machine and a 140 is the same threading as a 130
try entering the sites as most I go to require an account ( free) to procedure to read or down load and that process would be better for you
I went google and typed in--user manual for elinta sewing machine model 130-- and the sites show 130, 140 and more so select a site and go from there
thee is also a www.youtube.com>watch that runs for 1.29 and shows how to thread an old elna sewing machine
you might pick up a clue from that film
Posted on Dec 17, 2016
How do you thread an elnita 200 ?
How to thread and use Elna SU sewing machine
Athough most likely not your model, threading instructions are pretty much the same for the majority of machines except in extreme cases. Of course, a manual for your machine would also be helpful, even just for the maintenance and use instructions.
Elna Elnita 200
Elna 240
Instruction Manual Elna Elnita 200
Tip: ALWAYS RAISE the presser foot when threading the top thread. Always start out with a brand new needle (and change it at least every 8 hours of sewing time).
Dec 04, 2017 | Sewing Machines
My Elnita 130 does NOT have the same pieces used for threading, plus her hand was in the way. How can I get a manual?
  • User manual ELNA Elnita 220 () - English Download PDF
    www.manuals.club/document.php?iddocument=Dgpkzpe7se
    ... Immediate download or search mode services : ... 30 pages Electronic file ... User manual in English is the only document available in our database for this ...
Dec 17, 2016 | Sewing Machines
Needles for elnita 220
How about:
Elna New Zealand Accessories Sewing accessories Needles
Looks like your machine takes the 130/705H needles. You probably can find them at sewing shops in New Zealand.
Jul 27, 2016 | Sewing Machines
How do I thread a elnita 200 sewing machine?
Perhaps this will help:
Elna Elnita 225 Sewing Machine Threading Diagram
HINT: Be sure to raise the presser foot BEFORE threading the upper thread. It releases the upper tension disk so the thread will seat properly. Do this every time the upper is threaded.
Jan 06, 2016 | Sewing Machines
I have mislaid the instructions for my Elnita 140. In particular, I need to find the instructions for threading, including the little bobbin that goes underneath!
This is a machine made under licence for Elna back in the 80's I believe. So should be a bobbin inside a bobbin case mounted vertically. Try this link for threading up, it should be very similar.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_225_threading_diagram.htm
Many machines have this bobbin case design and they all work much the same way, you need to place the bobbin into the bobbin case with it turning the right direction, click the thread into the tension spring on the outside of the bobbin case then latch it into the rotary hook of the machine, usually there is a little latch on the bobbin case that holds it in.
Top thread is usually fairly obvious, from the spool through an eyelet, through the take up lever, through a tension device, then down to the needle.
Always thread up with the pressure foot raised as this opens up the tension device and allows the thread to seat in correctly.
You can probably buy a manual for your machine from either sewusa.com or www.sewingpartsonline.com or "sewing machine relics" websites. Or just search ebay, there are several vendors who sell pdf copies of different manuals there.
I hope this helps you get sewing with your Elnita, four thumbs up if so.
Aug 21, 2011 | Sewing Machines
Hello! I'm a beginner at sewing and recently inherited an Elnita 130 sewing machine. Does anyone know how I can find a manual for this? I have searched a number of websites selling sewing machine...
You can check this out. Doesn't list your model, but it is most likely similar to the 120 and 140. Usually, the only difference between one model and the next is one will have a few for stitches or added functions. The basic operation is probably the same:
Elna 110 120 140 Instruction Manual
Elna Sewing Machine Manuals Instruction and Repair Manuals
May 25, 2017 | Elna Sewing Machines
How do you thread an Elnita 140 sewing machine that is really old but can still work?
It's easy! Start from the thread holder at the top and go left - hook it under the hook which is behind the round disc that the bobbin winds around, then forward down thru the tension, then under the straight metal bit that's below and slightly to the left of the tension, then up into the hook (slide it behind and then slide forward into the hook), then back down and flip it into the small hook (which is just under the 'straight metal bit' mentioned above) and thru the needle! :-) Hope that helps. The machine might be an oldie but it's a goodie! cheers Lynda
Apr 02, 2010 | White Sewing 1888 Mechanical Sewing...
Sewing Machines Logo
98 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
