Question about Kitchen Ranges
My stove clock just blink, the oven light works, but there is nothing else that works, help
jsrock516
  • 5911 Answers
SOURCE: oven display and oven are not working AT ALL
Most electric range ovens are controlled by the electronic oven control (EOC). If your oven is not working and there is no display on the clock, more than likely you have a bad EOC. The board is not serviceable and has to be replaced. I hope this helps.
Posted on Jul 25, 2007
KOakaKO
  • 135 Answers
SOURCE: Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Posted on Aug 09, 2007
  • 23 Answers
SOURCE: GE Spectra range
All of the items you mention that do work, are 120 volt items.
All the items that do NOT work are 220 volt items.
Sounds like you have a voltage problem, you will need to use a meter to check if you have 220 volts a/c to the outlet the stove plugs into. Take care when doing the following, you will be around live voltage and could get hurt. If you are uncomfortable working with a live circuit best to call someone in to do it for you. Check for 220v at the outlet for the stove (where the stove plugs into), if you have it there, go to where the cord attaches to the stove and check at that point. You should have either a 3 or 4 wire cord on the stove, On the rear of the stove there is a terminal block that the cord is fastened to. Between RED and BLACK you should have 220v, between RED and WHITE and BLACK and WHITE you should see 120v. Another thing to check is that the nuts holding the wires from the cord to the terminal block on the stove are turned down tight. A loose connection there will give you the same problem you have as well.
Posted on Feb 19, 2008
blueextc3221
  • 15935 Answers
SOURCE: GE Stove clock shows FFF and oven will not work
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 13, 2009
  • 15 Answers
SOURCE: clock and light in oven work but stove and burners will not
Sounds like the wires connecting your control panel to the individual heating elements have either shorted out or been disconnected. Try taking off the control panel board and testing the connections (the four on the sides of the circuit board in the middle, and the two five pin and one three pin connector on the mainboard). If they are good, then your problem lies in the control board itself and will require a replacement from Whirlpool. Depending on if you have the touch sensor board or a push switch, it can run upwards of a few hundred bucks.
Posted on May 26, 2009
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
No power , no clock, timer, no auto lighting in oven or stove burners, no lights nothing
Some stoves have secondary fuses inside the stove. Check these fuses.
Nov 19, 2011 | Kenmore Kitchen Ranges
Stove top or oven doesn't heats. range type is a accubake system
Have you check the outlet to see if its geting power, if not, check the main breaker in the breaker box, you may have to turn the breaker to the off postion and then back to the on postion, if power is going to the outlet your stove should work.
Feb 12, 2010 | Kitchen Ranges
Oven will not turn on. Stove top works but Oven elements will not. Oven on indicator light does not go on either
The timer is bad. The timer is a PC Board (Printed Circite) that operates the clock and oven. The stove top eyes are operated by their on switches and have nothing to do with the oven or pc board. Some of them are expensive but not difficult to replace.
Please rate this solution if helpful
Aug 21, 2009 | GE Ovens
Oven does not work
Open the control panel to expose the clock/oven control.
With a volt meter verify incoming voltage to the clock control.
Check all wires for good contact.
If it still does not work replace the clock.
Remember to unplug the range to check the wires for good contact.
Mar 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Electric range burners and oven element just stopped working. Burner indicator light came on and oven temp setting displays correctly. Clock went into set mode automatically, though. Burner came back on...
check the power behind the stove, the outlet for 220 volts, i just fix one with the same problem, it was getting 110 volts but not the 220 volts. so there was nothing wrong with the stove but with the power source.when the stove indicator lights work and the clock, it means that only 110 volts are coming to the stove.
Dec 10, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Aug 09, 2007 | Frigidaire FES367 Electric Kitchen Range
Oven display and oven are not working AT ALL
Jul 24, 2007 | Whirlpool RF3020 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
