Question about Toshiba Televison & Video
I need to fine tune the speed on the Toshiba SE-R0180 VCR.
    Top Expert:
  • Toshiba Master
  • 80,339 Answers
There is no speed adjustment, if you think it has a speed issue then it is either the belts or the motor speed control board. I would replace all the drive belts first.
Posted on Dec 16, 2016
How do I unlock region codes on a Toshiba SE-R0220 DVD/VCR player? I've tried many codes for other toshiba DVD players but none of them work :(
The Toshiba SE-R0220 is the REMOTE model number not the DVD/VCR model number!
You need to find hacked firmware for the DVD/VCR model number you have that releases the region settings.
Write it to a CD RW or DVD RW disc and follow the instructions for updating the firmware.
There is a chance that the firmware will not update correctly and you'll be left with a DVD part of the system that doesn't work.
Nov 03, 2016 | Toshiba Televison & Video
Hello my Toshiba SE-R0398 controller is not working. I ahve tried changing batteries. Any possible solutions to this problem?
Search Results
    Where is my User's Guide / Owner's Manual? - TOSHIBA FORUMS
    forums.toshiba.com/t5/Toshiba-Forums.../Where-is-my.../268741
    May 28, 2013 - Answer. Most products do not include a printed manual but Toshibaoffers free, downloadable PDF User's Guides at support.toshiba.com.
    1 - Toshiba Blu-ray Players : Questions, Answers, How To ...
    answers.toshiba.com/answers/0293/category/.../blu.../questions.htm?...
    It had been working fine. Wired to modem, home computer working fine. It does a ...My remote SE-R0377 will not operate my BDX3200KY player. Im not sure if ...Missing: controller
    Remort se-r0398 not working - Fixya
    www.fixya.com/support/t16019942-remort_se_r0398_not_working
    Jan 20, 2013 - remort se-r0398 not working remote and buttons on blu-ray player not working model bdx1100kb - Toshiba SE-R0398 ... Question about Toshiba SE-R0398Remote Control AH802703 ... I need help with syncing my controller!
    Toshiba Blu Ray Remote ' eBay
Jan 14, 2016 | Toshiba Computers & Internet
I'm not sure how to connect my Toshiba SE-R0346 to my Sanyo TV. I plugged the cable line into the "Antenna in" port & then another cable line from "Antenna Out" to my TV. If I...
Exactly as you have done is fine all you need to do now is play the tape, (so you know what to look for when it is displayed on the screen), decide which channel you want to view the vVCR through, say 9, select the channel and set the TV to search tune on that channel. Store it when your taped programme appears.
Alternatively, have the set up as you have described and press auto install. That will retune the whole of the TV and include the VCR.
Hope this helps.
Nov 03, 2010 | Toshiba Televison & Video
I inherited an old Sony Trinatron TV it's working fine & have just bought and LG VCR to replace a VCR that broke which also works fine. The problem is in tuning the VCR into TV. I automatically tuned...
Depending on where you live you might have to go buy an HD antenna and scan for channels and hope you can get a PBS station or something to get you off of zero and then go into the menu and manually program a channel you can use to tune your VCR maybe that might do the trick
Jun 22, 2017 | Televison & Video
Remote control
used speed button on remote
Dec 30, 2008 | Toshiba MV13P2 13 in. TV/VCR Combo
Can't receive proper dvd/vcr signal
Your Toshiba TV uses the American NTSC standard.
Your DVD/VCR uses the Australian PAL B/G standard.
Unfortunately the two are not compatible as they stand, but there may be an option in the DVD/VDR menu to force the output to NTSC. This varies from make to make.
Another option would be to modify your main DVD player to make it multi-region so it will play ALL of your DVDs. Some models can be modified with a simple handset code, some can be modified with a software update, and others need an internal modification.
Post your make and model, and I can advise you on modification.
May 14, 2008 | Televison & Video
Tuning my Toshiba V-711B VCR
Get your **** out and shake it around.
Jan 06, 2008 | Toshiba Televison & Video
Toshiba tp50f60
1. Check the TV's horizontal and vertical hold. 2. If there is a VCR connected: Shut off the VCR. If the problem clears up, the VCR is not properly ?fine-tuned.? Turn the VCR on and troubleshoot the VCR problems. 3. If a converter is connected to your TV and VCR: The VCR needs to be on channel 4. VCR may not be ?fine-tuned? to channel 4. Locate and adjust the fine-tuning mechanism until the picture comes in clearly. The <3/4> switch may be in the wrong position. Locate the switch on the back of the VCR and set it to <4>. 4. Check the fine-tuning of your TV. good luck :-)
Jan 11, 2006 | Toshiba TP50G60 50" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
