Question about Garden
My 1989 snapper riding mower seems to have stretched..suddenly the belt is too tight..is there an adjustment to make the front closer to the back
    President:
  • 1,273 Answers
Yes. Look at the tube that runs from the back to the front. Youll see a clamp on it. You can make adjustments there.
Regards, --W/D--
Posted on Jul 20, 2009
How long is the deck belt for a snapper riding mower LT 150H38IBV
Go to the Snapper Website, Go to Manuals/Parts lists, enter the model and serial number of the mower. Scan for the proper diagram, copy the belt serial number. Go to a belt specialty retailer, present the belt serial number. They should be able to supply the belt length, and probably the belt.
Sep 12, 2015 | Snapper Garden
How do I get the deck drive belt on?
If the belt seems to short most of the time you only have to push the pedal in that makes the mower drive pulleys closer together.
This makes the belt slide over the pulleys and when you release the pedal the belt is tight and drives the mower.
Apr 08, 2014 | Cub Cadet LTX1040 Deck Belt 2009 Only...
Snapper 23 series mower blade will not engage
sounds like you belt is disengaged or just wore out, these type belts look good just to look at them, but they can stretch and get rounded a little bit of can mean a lot
Apr 05, 2014 | Snapper Garden
Snapper riding mower runs but wont pull itself
first check the friction wheel that drives the rear axle then look at the cable adjustment you may need to move the small rings around the pedal if all that looks good loosen the pulley assem away from the engine closer to the axle
May 16, 2012 | Garden
Belt adustments for a ride on murry mower
hello ann, as far as i know there is no belt adjustment on a riding mower, the tenser pulleys keeps the belt tight, if there is access slack than the belt is stretched and needs replacing,hope this helps,
Feb 15, 2012 | Garden
The belt will not get tight. the pully needs to be
When looking at the belt system the pully would be the one that actually puts pressure on the belt. Adjust it so that it sits closer to the belt when not depressed, this way when depressed it increases the "tightness" of your belt.
Apr 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I own a Snapper riding mower, hydrostat drive, 14.5 Hp, 38 cut. Reverse speed has suddenly been reduced to a crawl. Could it be the brakes need adjusting or is the engine/transmission shot?
could be a linkage came loose, or that the fluid level in trans is low, has nothing to do with engine but the hydros are prone to failure, also the hydro is driven by a vbelt which can stretch and mimic a trans problem
Sep 30, 2009 | Omega Rear Drive Wheel Snapper Mowers
Problem replacing belt on a ols rear engine snapper?
what kind of mower & model # i may be able to help thanks wade
Jun 22, 2009 | Garden
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
