My router password was changed and my Alexa does not work. Need help.
I just switched to a different internet provider. Alexa says she is having trouble connecting. What should I do?
You probably need to connect to your new wireless router.
Open the Alexa app.
In the Alexa app, open the left navigation panel and then select Settings.
Select your device and then select Update Wi-Fi. If you're adding a new device to your account, select Set up a new device instead.
On your Echo device, press and hold the Action button for five seconds. The light ring changes to orange, and your mobile device connects to your Echo device. A list of available Wi-Fi networks appear in the app.
Note: The Alexa app may ask you to manually connect your device to your Echo device through your Wi-Fi settings.
Select your Wi-Fi network and enter the network password (if required). If you don't see your Wi-Fi network, scroll down and select Add a Network (for hidden networks) or Rescan.
Optional - Save your Wi-Fi password to Amazon: Any Wi-Fi passwords saved during setup automatically appear when you connect a new Alexa device to the same Wi-Fi network. The password is also remembered if you switch between saved Wi-Fi networks. For more information, go to Saving Your Wi-Fi Passwords to Amazon FAQs.
Optional - Connect to a public network: Enter any required information if you are connecting to a public network that requires a web browser to sign in, like a school or hotel. The information could be a pre-shared password, room number, or just a button to accept conditions for using the network. This information cannot be saved to Amazon. Contact the network owner for more information.
Select Connect. After your device connects to your Wi-Fi network, a confirmation message appears in the app.
Jan 25, 2017 | Internet Computers & Internet
Why can't I connect to home WIFI?
Firstly, I would reset the router by removing the power for 5 minutes and then try again.
Jan 21, 2017 | Samsung Computers & Internet
I live in Ireland and I can not download the Alexa app for my Echo dot.what it says when I to download that this isn't available in your Country How will get the app
Can I use alexa.amazon.co.uk on a mobile browser.
Yes, initially it will tell you to use the app, however you can use your mobile browsers optino to display the desktop version of the website, it will work fine.
Can I get alexa app for iPhone?
The Alexa app isn't available on the Irish Apple App Store, however it is reltivaly easy to temporarily change your app store to the UK App Store and download it from there after which you can change it back to the Irish app store.
Can I get the alexa app for Android?
The Alexa app isn't available in the Irish Google Play Store. However it is possible to install the app by downloading the app to your laptop and sideloading the app to your Android phone. You can do a google search for more details on how to do this.
Will I be able to use my Irish address in the app?
Sort of. Amazon uses the Microsoft Bing Maps for it's addresses. Bing Maps address database for Ireland is very poor. Your address might not work, however you might find that a near by street address will work.
Jan 04, 2017 | Computers & Internet
I recently installed the amazon alexa app on my kindle fire and then it connected all my other devices. It was working until I installed a new router today. Now I can not seem to connect. Help
You likely need to reset the wi-fi connection for Alexa so that ti connects to the new router. Make sure that the IP addresses are the same from the old router to the new one. Some use a host number of 192.168.1.1 and others use 192.168.0.1. And of course, if you changed that, you need to match Alexa to the new IP range. Plus verify that the SSID and access password are the same on the new router as you used on the old one.
Jan 03, 2017 | Amazon Tablets & eReaders
How to change password of dlink router 600 without reset
the default dlink password is password or 1234
if that doesn't work then the password has been changed and you will need to reset the router to factory defaults. hold the reset button for 30 seconds while powered on.
Mar 04, 2012 | D-Link DIR-600 Router
Cant find password for Belkin F5D9230-4 G plus mimo router
If you are talking about the password to log in and make changes to router settings, according to the user manual for this router, found HERE, the default password is no password, in other words, leave it blank. If that doesn't work that means someone put a password on it and you will need to reset the router in order to log back in and make changes. If you need help with that, refer to the manual, or reply back to this message and I will help walk you through it.
Jul 01, 2011 | Computers & Internet
Password (admin) not working when i tried to set up my dir-615 d-link router
Greetings,
If you have not changed the default password for your router, it is blank. Also, make sure you change the password from its default. If you need more assistance, please post a comment and I will do my best to help you with the setup.
Apr 18, 2011 | D-Link DIR-615 Router
I need to change my password but i cant find my disk. I need instructions on how to do this because i can't connect to my netflix off of my dongle. but my laptop works wireless
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
Feb 17, 2011 | D-Link AirPlus DI-524 Wireless Router
I cannot access my D-Link Wireless Router, i'm trying to change my password but i cannot access the configuration panel, i have tried many alternatives.... however, i cannot find out what my password is,...
There a great article at General Router Setup.
Jan 21, 2011 | D-Link Wireless
I want to change my password lynksys wrt150n.
Are you speaking about the wireless network password?
For this you will need to access the setup page of the router?
Connect the computer to the router with the Ethernet cable.
open the setup page of the router.
Go to wireless tab and change the wireless settings.
If you want to change the ' Router ' password then go to administration tab and change the router password.
Click Here for more information about the routers and network
Oct 19, 2010 | Linksys Wireless-N WRT150N Router
Computers & Internet Logo
David Payne
David Payne
