Direct can't even hook up on and off or volume to remote as none of the codes work do you have other code numbers to at least try
I just changed from dish to direct and dish couldn't program it either I did find the right code however this product wouldn't let you program it I like the tv however this is rediculos that you have to use 2 remotes for the most common thing.
  • Televison & ... Master
  • 6,694 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily......
http://electro-medical.blogspot.com/
Posted on Dec 17, 2016
None of the codes listed works for my panasonic television. None of them will allow me to use the channel or volume buttons and only one of them allowed me to turn the tv off. Now that one doesn't even...
Hello
I'll give you some universal remote control codes for Panasonic to check it with your remote control They are used as general universal codes for panasonic.
Three digit universal remote codes to check with are:
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit unvicersl remote codes to check with are:
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 21, 2011 | GE JASRM24912 Remote Control
Direct TV remote
I think you mean Hughs when you're referring to your direct Tv remote? And you want that remote to turn on/off your Sylvania Tv, right?
I'd need to know the Hughs model number on the remote to know if it's a four or five digit code requirement. But here's a site that might help. http://www.remotecodelist.com/remotes/
Scroll down to Hughs and that link should take you to the DTV site where they have a wealth of info regarding codes. Find your model number remote control and you should have a list of possible codes to try.
If all this doesn't work let me know and I'll research sme more.
Good Luck!
Bill
Nov 25, 2007 | Sylvania SH50102 LCD Remote Control
I have an RCA L40FHD41 television and a Direct TV remote RC65R. None of the codes for RCA on the Direct TV website work. What code needs to be entered so that I can control the televsion from my Direct...
try these codes " 11447 11347 11781 10029 12187
10747 11147 11247 11547 10174
10679 10774 11922 11948 11958
10038 10093 11661 11917 11953
12002 10051 10090 10278 11047
11919 "
if those dont work then try this: "
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
Set the "Mode Switch" to the desired mode such as TV for a Television.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the code "991" followed by the "device number"
for Televisions
for "AUX 1" devices - VCRs or DVDs
for "AUX 2" devices - Audio
You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
You can try out each code by pressing one or more function keys such as power, volume or digit keys.
When you've found the setup code that works for your device, press the "Select" key. "
Sep 11, 2010 | Universal Remote Control DIRECTV Universal...
Cannot program direct tv remote to turn tv off/on or sound up/down
called funai, gave me number to call emerson. emerson said they give codes to direct tv., call them. called direct tv. said they have 12 codes, they would give me codes, the rest is up to me. none of the 12 codes worked. stuck with using 2 remotes. bummer!!!!!!!!!!!!
Nov 30, 2009 | Emerson Televison & Video
Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Jan 04, 2009 | Televison & Video
Remote Control Code for Element LCD TV -- & Direct TV
We cant find our original element remote control. I just tried 10178 on the direct tv remote control and it worked YEAH!!!! We just can't do the screen size edit thing with it :(. Might still have to order a replacement element remote. This works for now. Thanks.
Oct 03, 2008 | Olevia LT32HVM 32 in. LCD Television
32" proscan dual hd tv can't get universal or direct tv remote to work what now
Get a universal from big box and program. If you can find a rca remote, it should be programmed already.
Craig www.classtorations.com
Jun 08, 2008 | Proscan PS32500 32" TV
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
LG 37LC2D TV Virgin Cable remote codes
I had the same problem with a LG42lf2500 I tried all codes that Virgin had listed none worked. I then started to program volume control stating at code 0001. 0007 worked for my LG TV LG42lf2500
Jan 08, 2008 | LG 37LC2D Television
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
