Question about Maytag Dryers
Hi Folks. Maytag gas drier. Does it matter if I install the new cycling thermostat I purchased 180 degrees wrong? There are no marks to tell me which side goes up.
The drier model number is MDG4000BWW. The cycling thermostat is Whirlpool part number 3387134. And as I said, I have no idea which is the top. It can go in 2 ways.
  • 222 Answers
You shouldn't have any problem.
Posted on Dec 17, 2016
  • 1 more comment
  • Plin Manoni Dec 18, 2016
    thanks for your answer,,the reason I ask is the flame stays on for the whole time the dryer runs.I figured the cycling thermostat would cycle the flame on and off but it doesn't. Since I don't have anything to judge it against I am not sure if this is normal and the machine is working as designed. Before I changed the 2 solenoids and the cycling thermostat I had the opposite issue, thing cycled on and off constantly and the clothes took forever to dry.
  • Merle Evans
    Merle Evans Dec 19, 2016
  • Plin Manoni Dec 24, 2016
    Merle, I guess you're right. Clothes are drying and the machine isn't over heating..Also, I heated up the stats and watched the Ohm Meter, working as designed. Thanks Merle and have a Merry Christmas.
What is max temp inside dryer during auto dry regular fabrics cycle?
Larry, I just did a test on two different dryers last month to see what the temperatures were for them. I have different brands than what you are asking about but here is what I found. On a gas dryer I found that the temperature went up to almost 180 degrees without any clothes in the dryer. The electric dryer went up to 133 degrees before it went into the cycle process. You do have a cycling thermostat that will keep it cycling around that temperature and then a high limit that will kick it out it the cycling one fails and that is normally in the low 200's where it is set. Hope this helps.
Aug 06, 2014 | Maytag Dryers
Whats the right thermostat for 1995 lincoln town car
You will get that at the auto repair house. They will get you the one that corresponds to the size of the engine. 180 degrees is common. Buy it here
List Price: $20.38
Save: $3.11
  • Low Price Guarantee
  • In Stock
STANT ENGINE COOLANT THERMOSTAT -- 180 degrees Fahrenheit opening temperature; A high quality, direct fit OE replacement engine coolant thermostat; With 90-day Stant limited warranty.
  • Material: Stainless steel
  • Product Fit: OE replacement
  • Quantity Sold: Sold individually
  • Anticipated Ship Out Time: 1-2 business days
  • Opening Temperature Rating: 180 degrees
View more Fits the following 1995 Lincoln Town Car submodels:
  • 1995: Base; 8 Cyl 4.6L; "GAS"
  • 1995: Cartier; 8 Cyl 4.6L; "GAS"
  • 1995: Cypress; 8 Cyl 4.6L; "GAS"
  • 1995: Executive; 8 Cyl 4.6L; "GAS"
  • 1995: Signature; 8 Cyl 4.6L; "GAS
Nov 19, 2011 | 1995 Lincoln Town Car
Drier heats up in beginning of cycle but after that never heats up again during that same cycle.
While you didn't say im suspecting it a gas heated dryer??
If so here is whats wrong with it;
The reason your gas heated dryer starts off heating ok,but a part way through the cycle it is no longer heating as it did when it started,is beacuse the coils that open the gas valve are getting hot and breaking down when they are warm. At start up of cycle the coils are cool,but when the dryer heats up as it runs the coils that are weak can not handle the heat and do not open the gas valve. Replacing the gas valve coils with fresh,strong ones will open the gas valve the entire duration of the drying cycle. All appliance manufactures use the same exact gas valve coils and label them with their unique part number. Having been in the service business i know they are all the same and the part number for the least expensive gas valve coils is 279834
They can be purchased at your local appliance parts store on online at
To replace the coils,remove bracket over them(dont worry about where it says dont grip thats for when dryer is plugged in) unplug them and install new ones,that bracket has notches in it and the coils have tabs that inter lock so they position them self exactly where they fit.
This is what the coils looks like
Aug 27, 2011 | Maytag Dryers
Which thermostat do I purchase for my 1994 Dodge Stealth (automatic SOHC)? Choices are Beck/Arnley 170 Degrees F, Stant 170 Degrees F, Stant 180 Degrees F, Stant 195 Degrees F.
either of these manufactures are good just install one with the manufactures recommended temperature rating,as the wrong temp range can change how the car will run.example gas mileage,running temperature,cooling fan operation etc.
May 01, 2011 | 1994 Dodge Stealth
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Maytag gemini ovens won't heat adequately
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
Feb 10, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Aug 03, 2009 | Maytag Dryers
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
1992 isuzu pickup timing
Sounds 180 degrees out. Move flywheel to top dead center. Remove timing belt and turn flywheel pulley ONE complete turn to top dead center. Then put timing belt back on with marks lined up.
Dec 15, 2008 | 1992 Isuzu Pickup
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
Dryers Logo
139 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
