Question about Conair Health & Beauty
Trying to turn my haircutting conair clippers into trimmers
SOURCE: conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Posted on Aug 02, 2009
  • 448 Answers
SOURCE: I don't know how or where to apply grease to my oster classic 76
The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). If you don’t have a tube of oster grease, a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear and teeth of bakelite gear). Also, the bakelite gear shaft has a hole down its middle and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The small pads on each side of the lever (in the case) are oiled, not greased.
Oster clippers, by the way, are known for getting pretty warm. Oster blade wash will help with that, as well as oiling the blades.
Hope this helps you.
Posted on Oct 11, 2009
  • 17 Answers
SOURCE: Putting back together hair clippers
are u talking about the clipper it self or the clipper blade i need to know which one
Posted on Nov 14, 2009
SOURCE: conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
Posted on Jan 15, 2010
  • 10865 Answers
SOURCE: Need replacement blades for hair trimmer
Hi. Order them from Conair: customer service representatives will be happy to help you. Please call 1-800-326-6247 for a Conair appliance.
Posted on Mar 25, 2010
Manual conair 2in1 chopper clipper/trimmer free to download
If that's not the 2-in-1 clipper/trimmer you have, go to and search for it.
Jul 14, 2011 | Audio Players & Recorders
How do you clean the clippers and keep them sharp?
You can use a damp cloth after use to remove hair and other debris. There isn't really a way to sharpen the clipper though. The work on more of a shearing motion, but if you notice it has a lot of pull, you can order new blades online.
Jun 17, 2011 | Conair 16-Piece Chrome Haircut Kit...
My boyfriend wants me to give him a tapered , short haircut? show me.
You will find an instructional video at Click on link below and scroll down for video
If this video does not suit your particular need, offers similar videos on some of the other hair clippers that they offer
Sep 29, 2010 | Health & Beauty
I have conair haircut kit 10 piece and i used it on my brother and it keeps pulling his hair and i turned the power on switch it still pulls his hair whats wrong with the clippers
Sounds like you may need the blade sharpened, it may be dull, otherwise the motor may not be functioning properly. Does he have thick or coarse hair? If so, you may need to go through it lightly in sections otherwise it will for sure pull, I learned that way back in hair school long ago. :) Goodluck!
Apr 02, 2010 | Conair HC90CS Hair Trimmer
I need a manuel for model hc200 conair hair clipper in a download form
Jan 25, 2010 | Conair HC200XCS Hair Trimmer
Cant change to tops on my clippers
you mean you are trying to change the length guides on your shaver? You have to start by putting the top (with the teeth) on to the clipper part first and then pressing down on the back of it to clip it into place at the bottom of the clipper.So, place the guide on top of the clipper... slide it forward so that the curved edge of the teeth so they slide OVER the clipper blades... slide it back slightly so that the teeth are gripping on to the clippers then push down on the bottom of the at the opposite end of the teeth and it should click right in.
Apr 24, 2009 | Health & Beauty
Health & Beauty Logo
55 people viewed this question
Top Conair Health & Beauty Experts
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
