Question about Briggs Measuring Tools & Sensors
My briggs and stratton runs fully choked but once you open up choke the engine boggs down and shuts off
    Top Expert:
  • Briggs Master
  • 12,962 Answers
Main jet is not feeding fuel to engine. Clean card.
Posted on Dec 16, 2016
Hard to start then would only run with choke fully closed. Open choke or put even the lightest load on the motor and it shuts down.
The fuel jet in the carburetor is plugged. The carb needs to be cleaned and the fuel passages need to be cleared with compressed air.
Mar 07, 2016 | Husqvarna CRT900 14-Inch Briggs Stratton...
My briggs and stratton engine throttle cable and throttle body wont engage,always wide open
Are you sure it's not a new style Briggs that uses the 'throttle cable' just as a shut off? Many new mowers on;y start and run at High Speed
Jul 05, 2013 | Briggs & Stratton Garden
Where is the choke
Many Briggs engine have a primer rather than a choke, the 675 series has a choke that is worked by an air vain, the choke is always closed when the engine is stopped, once the engine starts air pressure from the flywheel pushes the air vain which in turn opens the choke to allow the engine to run normally, there is also a version with a bi thermal switch on the back of the muffler, as the muffler heats up the switch opens the choke.
Feb 12, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Motor will run fine with the choke on , but push
The governor is out of adjustment. It will be located on the side of the engine with a rod pointing downward with a weight
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 20hp twin cylinder runs only with full choke
Had one on my saw mill had this problem as well Try pulling bowl off bottom of carby as the float can get **** with old fuel especially ethanol fuels as they attract water bowl is normally held on with one center screw on bottom of carby. Note always turn fuel off and let engine run out of fuel as this stops goop from building up in carby
Sep 04, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
64 people viewed this question
Top Briggs Measuring Tools & Sensors Experts
BrikimG
Level 1 Expert
Lawrence Oravetz
Are you a Briggs Measuring Tool and Sensor Expert? Answer questions, earn points and help others
