Question about Dayton Heating & Cooling
Dayton furnace / blower won't turn on - Dayton Heating & Cooling
    Top Expert:
  • Dayton Master
  • 77,932 Answers
Test the blower motor relay and see if it is working.
Posted on Dec 16, 2016
Heating furnace blower won't stop
Check out the afc could be dirty remove and clean back of it , or replace afc , also check fan on fan off settings on afc
Jan 10, 2013 | Dayton Gas Furnace Heater
No problems, would like to find out the best way to remove blower for cleaning on an intertherm gas furnace mgh 075 ina mobile home
Generally ther is two screws at the base of the blower housing which hold it in place, remove the screws and pull, slide the entire assembly out. You will have to disconnect the electrical wiring to the blower and possibly the limit switch on the side if equip.
Aug 23, 2011 | Dayton Gas Furnace Heater
Furnace will kick on, begin heat up, go to the point where the fan should start and the whole thing shut down. If I move the thermostat down below the temp it show, it will start again and do the same...
Sounds like the blower motor is bad and then the unit is kicking off on high limit....
Probably nothing you can do with out getting a new motor to replace the bad one...
Feb 02, 2011 | Dayton Gas Furnace Heater
The pole buiding 24 in hanging Dayton sometimes the blower comes on like after 5 minutes after everything else kicks in and sometimes like when its supposed to and sometimes not at all?? All the electric...
I'm not sure whether this is a gas unit or not. With many gas heaters, the blower comes on when the heat exchanger gets hot enough and goes off once the heat exchanger cools. Other things are happening before the blower goes on. The blower is normally controlled by a "fan control thermostat". This stat actuates the blower when the furnace is hot enough so that cold air is not being blown around and allows the blower to run until the furnace cools enough to get out the remaining heat after the flame shuts off but not so long to again allow cool air to blow around. If this fan control is malfunctioning, you will get erratic runs from the blower or the blower may not run at all or run long or continuously. The fan control is the first thing to check.
Jan 31, 2011 | Dayton Gas Furnace Heater
With Model #GF9s120d20up11g, gas furnace, the blower model behind first top access door is very hot but furnace won't ignite, what"s the problem?
You did not mention if the blower is turning or not. If so, take a jumper wire and jump out the pressure switch to see if the igniter glows. If so, you either have a bad pressure switch, the inducer motor (the hot one) is not blowing enough to close the pressure switch, blockage in the condensate hoses or blockage in the vent system. If the blower does not turn, replace it.
Jan 16, 2011 | Dayton Heating & Cooling
Where is the location of the air filter on a dayton fuel trimmer gas furnace and what type does it take?
The filters are usually located inside the furnace above or below the blower motor, inside of a compartment door. That is only if you do not have filters in the grills inside the house. The type would be hard to say, but when you find them (theres usually 2 or more), they will have a size on them and you can pick them up at Home Depot, Lowes, Wal-Mart, etc. Hope this helps.
Dec 15, 2009 | Dayton Gas Furnace Heater
The furnace is not getting power to ingination board.
check the air filter is clean , see if the theromstat is turned up to high ,
does it have a hot surface ignitor i take it this a gas furnace ?
Dec 11, 2008 | Dayton Gas Furnace Heater
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
Dayton Gas Furnace - Blower will not shut off
Try national energy they are on line and carry most spares
Apr 06, 2017 | Dayton Gas Furnace Heater
Heating & Cooling Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
