Question about Vizio Televison & Video
I am having problems with the menu on my Vizio 55 in flat screen TV.
When the menu function is selected by remote or by the Menu button on the set The menu options show up for a second and then closes. I am wondering which module in the set contains the menu circuits
unclejed
  • 26 Answers
SOURCE: pop up box appears periodically
try bringing up the menu, and see if there's an option "factory default", and try that. you didn't mention what button on the remote you press to get rid of the popup, or what feature you are turning off to get rid of the popup,
Posted on Jun 28, 2006
SOURCE: Can't turn off closed caption & not its not on the TV menu
I went to menu, special features. then select analog CC and selected OFF.
Posted on Jan 04, 2009
joez47
  • 61 Answers
SOURCE: menu pops up while tv is on
Isolate the problem by removing the batteries from the remote. If the problem goes away replace the remote: "CHEAP" .
If the problem does not go away, the problem is in the TV, repair the TV "EXPENSIVE" !
Posted on Aug 29, 2009
  • 11 Answers
SOURCE: Gateway TV On Screen Menu stays on and scrolls through options
did you ever get this fixed
Posted on Jan 24, 2010
jyackle5
  • 8197 Answers
SOURCE: i want to configure my direct tv remote (hughes)
Actuly you can get the remote to work with your TV. I also have direct tv and a vizio and my direct tv remote works the tv. I need to get you remote model # to be able to help you program the remote. Once I have that I will give you the instructions on how to program it. Please add a commet when You can provide it to me.
Thank You
Posted on May 09, 2010
We have a Model un40eh5300fxza tv, where on the remote is the OK button
    images for where on the remote is the OK button
    More images for where on the remote is the OK button
    RC: Tv code so i can use ok/select button on comcast remote
    www.remotecentral.com > ... > Consumer > Original Equipment Remotes
    Mar 3, 2010 - 13 posts - ‎7 authors
    I have the comcast dark grey remote and a vizio lcd tv .when i press the tv button i then can press the menu button it brings up my tv menu and ...
    Button Functions by Remote ' MyDISH ' DISH Customer ...
    https://www.mydish.com/support/.../remotes/button-functions-by-remote
    Register, Button, Button Sub-Category, Function, Condition ... on screen menu/pop-up, -. 2, Color Buttons, -, -, Function varies by screen and customer selection.
    Select/OK button doesn't work when Using Comcast remote with ...
    www.avsforum.com/...remote.../1533595-select-ok-button-doesn-t-work...
Jan 07, 2016 | Samsung Televison & Video
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
How do get closed caption Vizio VF550M 55 in. LCD HDTV?
Closed Caption availability may depend on the source. To enable caption viewing, press Menu (on the TV or the remote). Navigate to the Setup menu with the Up/Down arrows on the remote or the Channel Up/Down buttons on the TV. Once Setup is highlighted, press the Menu button again. Repeat the up/down navigation to the CC menu and Menu to select. The first option should be On/Off. Now use the left/right arrows on the remote (or volume up/down buttons on the TV) to choose the desired CC state. Press Menu to save or Last to cancel and return to the previous menu. Press after pressing Menu to return to the previous menu. If your content is from a digital source, you can make adjustments in the appearance of the captions by navigating to those sections of the CC sub-menu. If you would like some idea of what the screen will look like as you navigate the On-Screen Display, see the manual on Page 41. Vizio makes the manual available on their support page. The direct link to the manual is cdn.vizio.com/documents/downloads/hdtv/VF550M/155Manual.pdf . (Note: you'll need Adobe Reader or a similar program to access the manual.)
For some content, you may need to enable the captions at a set-top box (cable/satellite receiver/etc.). In that case, consult the manual for those devices or post a comment with the make/model for additional help.
I hope this helps.
Feb 13, 2015 | Vizio Televison & Video
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
Menu button stopped responding
If only one button does not work at all or all do not work the unit may have a lock out feature that would be explained in the owners manual.
Apr 10, 2012 | Vizio Televison & Video
New 47" Vizio tv.
Look at your remote and there should be a menu button. Once in the menu you will see a screen section that will let you select between 4:3, 16:9..... Toggle through those until you find the one that works with your tv.
Also there may be a button on your remote that looks like a box with an arrow pointing left and right. Click on that and it will toggle through the same thing mentioned above
Jul 25, 2011 | Vizio 42 in. LCD TV
We have the M220MV. Cannot change channels using the numeric keypad on the remote. I know it should be possible, the manual says you can change channels this way. If not, the last channel button would be...
Hello
Reset your Tv to factory settings. It will unlock all locks including front panel lock.
Reset All Settings
Return all Picture and Audio settings to factory default. A screen will come up to confirm your
selection or to cancel it. Press Left or Right Navigation buttons to make the selection, and then
press OK to accept it.
Setup Wizard
Use this function to return to the Initial Setup menu
Go to its user manual for Initial setup menu details.
OK.
Apr 24, 2011 | Vizio M220MV 22 in. HD-Ready LCD TV
How to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Vizio M550NV 55 in LCD HDTV
Cannot remove the 'store' settings from 55 inch vizio bought at costco today When i push the "OK" button on the remote it 'thinks' that I'm pushing the 'menu' button and gives me the 'menu'...
Unplug the set for 20 minutes then plug it back in and turn it on. You should see a setting that says HOME____STORE on the screen. Make sure you high-lite HOME. Then continue on.
Dec 27, 2010 | Vizio XVT553SV 55 in. LCD TV
I am having a problem with my new vizio tv. I am
Try this solution....
1) On the original TV remote press the menu button.
2) Scroll down to SETUP and press MENU button to select it.
3) Scroll down to WIDE
4) Use the LEFT and RIGHT arrow keys to adjust to your viewing preference.
**** NOTE: When you adjust these settings you may notice a difference in the picture on the HD channels. When you are viewing an HD channel but the network is not broadcasting that show in HD they push in the sides to compensate and try to make it a sharper picture but know this is normal.
Good Luck and please rate this solution....
Jan 10, 2010 | Vizio VF550M 55 in. LCD HDTV
Televison & Video Logo
22 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
