Question about Epson Stylus Office Bx305f Inkjet Fax Scan Copy 5760 X 1440 Dpi
I have just replaced my magenta cartridge on BX305f printer and it does not recognize cartridge tried to reset factory settings undoing electricity and reconnecting still comes up,with same message
    Top Expert:
  • Epson Master
  • 77,202 Answers
Is this a new cartridge or a refilled one, if it is a refilled one then you found the problem, most printers have a way to bypass this problem, my Canon you press and hold the "Stop" button.
Posted on Dec 16, 2016
MFC-J430W will not recognize any new magenta cartridge!
When installing the cartridges, it is important that you insert them from left to right with the black cartridge first and the magenta cartridge last. The reason for this is because the magenta cartridge has a clip on top of it that goes into the cartridge door sensor. The clip needs to push the sensor in so the printer is able to function with the cartridge door open. If you insert the magenta cartridge first, the printer will think the cartridge door is closed and you will get a error message for the other missing cartridges.
May 29, 2013 | Brother Office Equipment & Supplies
I have a Canon iP6700D. I refill my carts. I have a resetter and use it every time. This time the printer won't recognize the magenta cart. I refilled it, reset it and replaced it as always. I...
If your printer did not good in times of reseting the cartridges do check the cartridge holder if the is some dirt inside or the terminal of your cartridge had wet by the ink when you refill the ink of your cartridges.
Aug 12, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
I have replaced the ink cartridge Magenta (T0813), with the new one, but the printer Epson R390 can't recognize it. It says Ink cartridge cannot be recognized. Make sure ink cartridges are correctly...
It might possible that the new cartridge is defective.
Try to turn off your printer, wait at least 3 minutes, turn back on.
This may reset the printer.
You could also try to remove your magenta cartridge.
Shake it a little, this will remove any trap air and fill the catridge cavity.
Reinstall the cartridge.
Jan 18, 2011 | Epson Stylus Photo R390 InkJet Printer
Hi. My printer will not recognize the magenta ink. I tried replacing it with 3 different new ink cartridges, but when I try to make the printer charge the new ink, it does nothing and says I'm out of...
Hi
Some ink printer had ink resetter and just go to ink set up.
If your printer have ink resetter, do it otherwise it will not recognized new ink installed.
If not, some new ink cartridge when the tape is remove, there are cases that the sticky leaf on the ink cartridge, just rinse it with warm water or alcohol to detect the ink cartridge. Turn off your printer and your computer. Then return the ink and open your printer and computer to print again.
Note : Use only ink that is compatible with your printer because it you use other cartridge it will damage the chip set of your printer and it will not recognized any cartridge at all. SO beware.
I hope it helps you.
Jan 12, 2011 | Epson Stylus Photo R1800 InkJet Printer
My Brother MFC 420CN printer indicated it was out of Magenta...so I replaced the cartridge. After replacing it asks "Did you replace Magenta?" I said "yes". Now it indicates "No Cartridge. Open scanner...
Yep, it supposed to **** your money out of you pocked until you come up with a right solution.
Try pulling your power cord when your unit is on and when it off. It might help.
Try a factory reset on your printer. It's called hard, cold, factory, deep reset that means same thing.
Resetting Brother Printer
You need to keep pressing the DOWN or UP keys a couple of times till you see 'Maintenance 99' displayed on the display. Then hold down the 'Set' button to go to standby mode. Please note that if you press the exit key only after typing in a single digit then the machine goes to maintenance mode in initial stages.
Sep 07, 2010 | Brother MFC 420CN All-In-One InkJet...
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer won't recognize the new ink cartridge
Each cartridge has a electronic chip pre-porogrammed at the factory.
If it is a reputable store they will exchange for the right color as they can return the PM to Canon as defective,
Mar 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
My printer doesnt recognize the color magenta it only
was your printer detecting the earlier magenta cartridges which you used?? if yes.get another magenta cartridge and try again.problem with the particular  magenta cartridge. if no.get your printer replaced.its a hardware issue.
Jan 19, 2009 | Office Equipment & Supplies
Epson R1800 printer won't recognize new ink cartridge
You can remove magenta & double check that some tape was not left behind on the contacts. Take a clean ragg & dampen it with alcohol. Clean the ink cartridge's (copper contacts & inside the the ink carrige). Re-install the magenta, (tight fit). Power off the printer. Wait a few seconds & power it back up. If it fails a second time with no other errors. Like the above. Than the magenta may be defective. Have a recipt? Return it for a replacment.
Feb 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Office Bx305f Inkjet Fax Scan Copy 5760 X 1440 Dpi Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
