Question about Bosch Water Heaters
I have a d3 error on my Bosch gas water heater. Do I need a technician to fix?
D3 says boiler external stb has tripped. Heating mode not possible.
  • 244 Answers
SOURCE: Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
Posted on Nov 01, 2009
peterrance19
  • 399 Answers
SOURCE: i AM GETTING AN A2 ERROR CODE
hi ill try to help the fault is in the overheat cutoff fuse its the white overheat wire fuse that wraps around the heat exchanger disconnect the plug connector between the fuse wire and the control unit ! using a multimeter check the resistance through the fuse to see if its bad !if its bad check to find the cause ie .a leakage of flue gasses on the heatexchanger also check the black rubber seals located at the top and bottom of the heat exchanger also inspect the seal around the viewing window on the heat exchanger then call tec support and report leakage areas also for fuse replacement the only number for tec support i can find is 08006423111 i do hope this helps
Posted on Dec 06, 2009
  • 20 Answers
SOURCE: Ferroli boiler error code A3
boilers need a certain amount of water pressure to operate as specified--there may be a pressure regulator valve, allowing a certain amount of water to your boiler, and when water is drawn elsewhere, there may not be enough getting to the boiler---this is one possible solution, but there are easily 20 more, and that is where a trusted plumber is worth it's gold...very difficult to diagnose most plumbing problems without being onsite
Posted on Mar 14, 2010
SOURCE: Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
Posted on May 17, 2010
  • 68 Answers
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
Posted on Jul 31, 2010
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
Water not as hot as it was.
Tankless require yearly service to keep burner and combustion parts clean and check electrical connections, gas solenoid, gas pressure, venting, etc.
Read product manual for advisories and recommended maintenance.
Yes, aren't you glad you saved the manual.
Always check that local area has affordable and qualified service technician for your brand before buying tankless.
Before calling service technician, copy following link for general troubleshoot resources, including some manuals, and links to Bosch.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Try turning temperature down.
The fact there is no error code, and the gas is not firing correctly, means you have a small unit with no error codes and PC board has failed ... or it means you have a unit with error codes and possibly bad PC board.
If problem is the PC board, then Bosch will send you new board, and expect same level of repair success as though your computer's motherboard was replaced.
You can buy ordinary box-store tank-type heater and install yourself same day for about $325.
Then maintain and fix it yourself. I recommend AO Smith/American/State/Reliance/Kenmore/Whirlpool since these are easy to maintain with clear directions in manual, plus AO Smith posts service manuals for the whole line of products, and any local plumber can fix them with ez-to-locate generic parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 07, 2012 | Bosch & Tankless Water Heater
Aquastar125WP is overheating and the strainer has been removed. We need to fix it. Have any ideas? Thanks for your support, Martina
Before calling service technician, open following links for troubleshoot resources:
The problem could be bad gas control solenoid, or bad sensor, or bad wiring or bad PC-board, etc, or combination of problems. Fixing one problem may not completely fix problem.
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/38b-125-series-bulletins.html
Before installing tankless water heater, read the service manuals and product manual to make sure you have testing skills and equipment needed to repair tankless gas water heater, and that you are prepared to buy expensive parts and do the recommended yearly and monthly maintenance.
Also check that area has qualified service technician, and that person carries parts on-hand, and is certified to service your model number. Keep Tankless manufacturer contact information on-hand, and be skeptical of promises of unlimited hot water, and effortless long-lasting water heating, and saving money. The only folks saying this are the folks selling the product, and not their customers.
Fix most tankless gas water heaters yourself, same day, all brads for about $350.
Sep 21, 2011 | Water Heaters
Our tankless water heat will not heat the water-it won't ignite
Question posted under Boasch tankless. Model number not known.
Before calling service technician, open following link for Bosch troubleshooting resources, including phone and contact for Bosch, error codes, and possible manual, plus hours of reading and research:
As you know from reading manual, tankless water heaters require yearly maintenance by trained service technician, or by homeowner. This action would check gas and pressure, venting draft, condensation drain, burner and combustion parts, igniter and-or pilot light, electrical connections, air intake and general condition of plumbing.
Problem you describe does not include error code.
Open following link for possible help with general plumbing problem:
Add a comment with model number that appears on side of unit, and I can directly locate possible service bulletins and further troubleshoot resources available at Bosch for possible do-it-yourself diagnosis and repair.
Sep 02, 2011 | Bosch & Tankless LP Hot Water Heater
I have a Bosch Tankless Water HEater Model GWH 2700 ES NG with an error code of A3. I was told to push reset and the problem would be resolved. This worked several times and now it doesn't work. ...
Yes. Contact Bosch.
Error codes are considered start-point for troubleshoot.
Tankless are complex electronic machines.
If on-site plumbers cannot figure out problem, then you need trained service technician with a service manual for your specific product, who can ohm-test the electronics.
Bosch will have a list of trained service technicians. And maybe Bosch has another step for fixing problem yourself.
Fix most tankless problems yourself, same day, for $330.
Aug 14, 2011 | Bosch AquaStar 2400ES-NG
I have a powerstar ae115 water heater that is 3 years old. The thermal cutout onthe left side keeps tripping. after shutting off the shower the temp on the top of the unit is reaching 185*f. I have...
You've done the required first-step troubleshooting and maintenance.
If thermal cutout keeps tripping, and unit is actually reaching 185, then something is wrong with wiring, temperature sensor, gas valve, or PC board. Or combination of factors.
Call service technician, and open following link for some Bosch tankless resources including Bosch contact information:
Jun 26, 2011 | Bosch PowerStar AE115 Tankless Water...
No Spark at the boiler end ,tried purging the system but still no luck water pressure is fine.???????
Before calling service technician, open following link for Bosch tankless troubleshooting resources:
Fix most tankless problems do-it-yourself, same day any brand, for $317
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 28, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
Bosch 25E natural gas heater has stopped heating the water Is there something basic I can do to correct this Thanks, Sam
1) Call service technician, and when that person arrives, ask about tips and tricks for maintaining tankless water heater.
2) Open following link for basic troubleshooting resources:
3) Add a comment with your experience so others with same problem will benefit.
4) Also take advantage of fixya expert assistance live.
Fixya is always less expensive than a service call, but does not take place of service call since you will be doing the work yourself, on a complicated appliance that is affected by perfect cooperation of internal parts, and external factors.
Apr 05, 2011 | Bosch Indoor Gas Tankless Water Heater...
Water Heaters Logo
382 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
