Question about Keurig Coffee Makers & Espresso Machines
Keurig 2.0 coffee maker seem clogged as hot water barely drizzle. Passed a solution through it but didn't help.
SOURCE: keurig coffee maker won't draw water from the resevoir
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
Posted on Mar 02, 2009
  • 460 Answers
SOURCE: hot water does not go through the individual cup
check to see if the outlet hole is plugged up and use a tooth pik to clean it out then try bo brew again..
Posted on Nov 12, 2009
cmccune04
  • 213 Answers
SOURCE: Missing Keurig part
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 13, 2010
  • 40 Answers
SOURCE: platinum B70 keurig coffee maker water heats up
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
  • 3 Answers
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Posted on Dec 31, 2010
I have a model K40 (the fifth Keurig I have purchased). This one now barely drips water, takes forever to make about a third of a cup of coffee
There are instructions on youtube for the proper procedures to clean a Keurig. If you ever ran anything but clean water through the coffee maker, like reheating a cup of coffee the grinds in the bottom of the cup clog the system. Watch the video it is usually done with a small paper clip.and vinegar
Aug 30, 2014 | Keurig Elite K40 Black Coffee Maker 1 Cup
Is it bad to use heated water inside of a Keurig coffee brewer..?
I had to take the cover of the K-cup cover, this is done by removing the 2 screws out under the cover while the handle is in the open position and then snapping it off. Pull the hose off the k- cup puncturer and clean it out from the top down this will clear out all the packed coffee ground in it. You may be able to clean it from the point up if you can find a very small pipe clean or something like that but I didn't have one so I pulled off the cover and went from the top down. I'd love to know how many people threw away these coffee makers because off this repair, I know my mom did before she talked to me. Good luck people.
Jul 17, 2012 | Keurig B30 Mini Coffee Maker
Keurig B40 problems
Clogged ports see page 18 Manual for assistance.
Feb 28, 2012 | Keurig Elite B40 Coffee Maker
Hi, My Keurig is heating water but water will not brew through machine. Help! Thanks, Cynthia
seems like hard water has clogged the small water lines, you need to soak it in clr or other de-scaler available from any hardware store. happend to my cappuchino machine a few times (:
Nov 23, 2010 | Keurig B100 Coffee Maker
Keurig coffei maker water gets hot water dosnt go in cup
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Oct 22, 2010 | Keurig B100 Coffee Maker
Keurig coffee maker is on, lights lit, machine said it is brewing but no water is coming out
Even though the light is on, this does not mean the element that heats the water is working. After you fill the machine with COLD water, and the light has been on for a few minutes, unplug the machine and dump the water out into a bowl. Carefully, feel the water. Is it hot? OR just warm? Or still cold? If it is warm, the element is not heating properly. If it is cold, the element is NOT working. If the water is HOT, then perhaps the tube from the water storage reservoir to the brewing basket is clogged. If that tube is clogged, it needs to be removed from the machine and cleaned out. If the element is not working, or heating the eater hot enough, that element needs replacement. Chances are, the replacement cost/cost of repair would be more then a new coffee maker.
Feb 03, 2010 | Keurig Special Edition B60 Coffee Maker
My keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Jan 02, 2010 | Keurig Special Edition B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
52 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
