Question about Vehicle Parts & Accessories
I have another remote and wanted to sync it with my vehicle. Same system the 477l.Avital.
4 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
logosc75
  • 625 Answers
SOURCE: My avital 477l starter has
The Zs mean that the alarm is in valet. To exit valet with the remote: open any vehicle door, press lock,unlock,lock. The zs should disappear from the remote allowing you arm the alarm.
Posted on Feb 16, 2011
  • 1833 Answers
SOURCE: replacement remote for avital 477L. how do i pair
Here I am described four ways to pair the alarm with the remote.
1st way:
Put the key in your vehicle's ignition and make sure all the doors and the trunk are closed.
Turn the key two clicks to the right, one click short of the "Start" position before you do anything with your replacement remote.
Press and release the "Override" button on your remote car alarm remote five times in less than eight seconds.
Press the "Lock" button on your car alarm remote.
2nd way
Purchase a new remote from the dealership or automotive store where your alarm system was installed. Make sure the remote is the same brand as the system that you have installed.
Sit in your car with your remote and ignition key. Insert the key into the ignition, turn it to the "ACC," or Accessories, position and leave the driver's door open.
Wait for the chimes to stop and press the "Valet" button on your remote.
Wait for the alarm to chirp once, press and hold the "Valet" button again and press the button you would like to program; do this while holding the "Valet" button.
Wait for the horn to chirp again and release the button that you are programming. Release the "Valet" button and remove your key from the ignition to end the programming of the new remote.
3rd way
if it has the button in the antenna. Turn the ignition on then off within 7 seconds hit the button(antenna button) 5 times it will chirp (telling you it's in program mode) if you have viper two button hit both buttons at the same time do both remotes one after the other (led will flash to confirm programming is done) this should fix your problem.
4th way
Click on the following link and go to the page no 3 and 4???
http://www.directeddealers.com/manuals/og/avital/G834002_07-04.pdf
LCD 2-way configuration, Standard 4-button configuration.
It will solve your problem. Best of luck.
Posted on Sep 14, 2011
acabral06
SOURCE: My Avital 477L remote got
http://www.remotesunlimited.com/faqs_question_7.php
This should help.
Posted on Sep 14, 2015
My CM600S remote start has stopped working What could be the cause of this?
Check fuses on control box. Make sure it is not in valet mode.
May 30, 2014 | 477L Ask RXTX HHU Remote
I dont have manual for 477l can any one help me with that
You will need to get the model number from the main module under the dash, not off the remote.
Mar 02, 2014 | 477L Ask RXTX HHU Remote
Had some work done on my 03 Eclipse and now my Avital remote start fires up then immediately dies. The security light comes on in the car. Do I need to reset something? How do I do that?
im willing to bet your mechanic seen a wire he didnt think belonged there and just cut it (happens all the time with aftermarket electronics)
Mar 07, 2011 | 477L Ask RXTX HHU Remote
My avital 477l starter has some Zs by the car and it won't let me set my alarm. How can I restart starter?
Feb 16, 2011 | 477L Ask RXTX HHU Remote
My car keeps on turning on by it's self and it does not have the timer set.
If your remote starter is activating "by itself" and there is no timed start setting initiated; the activation wire (white with blue stripe) is touching ground under the dash. Locate the command module of the Avital unit and isolate the white with blue wire by applying some tape to it.
Feb 04, 2011 | 477L Ask RXTX HHU Remote
My Avital 477L remote got wet. It is dry and working fine, all the lights come on. However it doesn't work with my car anymore. Is there a way I can reprogram it.
Open door, turn ignition on, press and release programming switch one time, press and hold programming switch while pressing lock button on remote. You should hear a confirmation chirp from unit.
Sep 25, 2010 | 477L Ask RXTX HHU Remote
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
