Question about Cell Phones
I have a vivofit HR and I am not able to get the weather on the device
I have the iPhone 6 and a weather application on the phone
I had to replace the batteries on my garmin vivofit and the time date is wrong how do I fix this?
Search Results You should synchronize your device to receive the correct time when you change time zones, and to update for daylight saving time.
  1. Confirm that your computer or mobile device displays the correct local time.
  2. Select an option: Synchronize your device to a computer (Sending Data to Your Computer).
v?vofit Owner's Manual - My device does not display the correct time
https://www8.garmin.com/manuals/.../vivofit/.../GUID-FF71ED02-BAE2-4992-BF85-66...
garmin vivofit manual change time Google Search
Sep 23, 2017 | Garmin GPS
My vivofit will not pair since i changed my batteries. I reset my band and reinstalled my app. Still when i try to pair, it fails. What am i missing? Pairing with a Samsung 5
Go into the WIFI menu of your phone and delete the old connection to this device and then power the phone off and also the device and then power your phone back up first and then the device and then make the connection.
Your phone or any WIFI device will always remember the old connection you have established and if something is changed; you tell the phone to forget that connection and power cycle both devices and start from scratch.
Dennis
Aug 19, 2017 | Samsung Radio Communications
How do I reset the time on Garmin vivofit
https://www8.garmin.com/.../vivofit/.../GUID-FF71ED02-BAE2-4992-BF85-661A5BF0
Nov 07, 2016 | Garmin GPS
Does the vivofit work with an android phone
Yes.only application to be installed on your phone
Mar 19, 2016 | Android Cell Phones
My vivofit won't sync when I press the button
Hello
Ensure multiple applications are not running simultaneously on the device you are syncing with.
Remove my Vivofit from the devices and re-pair it.
If issues persists, simply delete and reinstall the Garmin Express application and it should solve the syncing issues with your Vivofit.
Jun 02, 2015 | Garmin Vivofit Fitness Band
How do i reset my time on my Garmin vivofit
You must sync your device with Garmin Express: Garmin Express
make sure your computer's day and time are also correct as that is where the VivoFit gets it's time from. You could also do this through select smart phones : Is my phone compatible with Garmins Bluetooth Smart products
Mar 08, 2015 | Garmin GPS
How to transfer contacts from Samsung to iPhone 6/6 Plus?
You just need a simple Android-iOS transfer tool. According to my personal experience, SynciOS Data Transfer can be a good choice. You can transfer your contacts, photos, musics, messages and so on by one click.
SynciOS Data Transfer For Windows
Nov 16, 2014 | Apple iPhone Cell Phones
When I push my application buttons like facebook, weather channel, yahoo messenger, it blinks but goes straight back to the main screen
You have a permissions problem with some apps. Try a total shut down and restart of the iPhone.
If that wont fix it you need to restore the iPhone with iTunes.
Jan 11, 2010 | Apple iPhone Smartphone
Iphone touch screen is not working. Restored the phone from backup succesfully, but screen still doesn't work. Phone receives calls, etc., but can't unlock or answer calls because screen doesn't respond to...
Even though the iPhonemag-glass_10x10.gif is a device that is extremely convenient to have, it still can cause frustrations. Specifically, there may be times when the touch screen does not work properly.
There are various problems the iPhone touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Of course, it is possible that the entire screen works, but is simply slow. Regardless of the exact problem, there are ways to troubleshoot the iPhone to diagnose the real problem.
  1. tep 1 Remove the wiping cloth that came in the small black envelope along with the iPhone. Wipe the smudges or dust off the screen with this cloth. It is best to wipe in a circular motion.
  2. Step 2 Do not put lotion on your hands and do not touch the screen if your hands are wet. Any kind of moisture can affect the way the touchscreen operates. Moisture sometimes slows the response time from the screen to the operating systemmag-glass_10x10.gif.
  3. Step 3 Check for a protective sheet on the screen. If there is some kind of a film or sheet on the touchscreen, the screen is likely not able to react to all of the sensitivities of the touch of a finger as it normally would.
  4. Step 4 If there is an application open and the touchscreen seems to not be working, simply close the application and retry it. A frozen application can usually be closed by pressing and holding on the circular button located just below the touchscreen.
  5. Step 5 Press and hold the home button as well as the reset button on the top of the phone to turn the iPhone off. A red slider will appear. Slide it to the right to turn the phone off. Press again on the "Reset" button on the top to turn the phone back on.
  6. Step 6 Completely reset the iPhone by holding the "Home" button and the "Reset" button for a full 10 seconds until the phone resets and the Apple logo appears on the phone.
    • If you are using the iPhone in cold weather and wearing gloves, the iPhone will not react to the gloves as it will to the touch of a finger.
    • If the touchscreen is dirty, do not run the iPhone under water. Doing this will likely ruin the phone, but even if it doesn't, it will possibly make the phone run slower.
Nov 15, 2009 | Apple iPhone Smartphone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
