Question about Vacuums
Battery "handle" slightly lifted
After removing the battery from its charger, the handle for removing the battery is slightly elevated and won't go back down. This means that the battery cannot make full connection with the stick vac, so I can't turn on the vacuum. Is there a way to fix this?
  • 4 Answers
SOURCE: Cordless vacuum WESTINGHOUSE WST1600A - problem with charger.
http://www.download-manual.com/shop/Westinghouse-c-145.html
Posted on Jan 16, 2009
  • 2418 Answers
SOURCE: Is it possible to replace the battery (loosing
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web.
Posted on Jan 27, 2011
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: My on off button won't stay pressed down so the vacuum won't stay running.
    Hi Melissa,
    I'm sorry to hear you're having difficulties with your DC17. If the on/off switch doesn't seem to be working correctly, it's best if you get in touch with us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Posted on Nov 14, 2011
    ercupa190
    • 12223 Answers
    SOURCE: The brush on my Hoover Windtunnel T series won't turn when I'm vacuuming carpet. It does, however, turn when I'm vacuuming bare floor, and I didn't think it was supposed to do that.
    1) test the belt +brush for worn and replace
    2) test the motor
    God bless you
    Posted on Jul 03, 2012
    SOURCE: I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery i
    If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
    Posted on Sep 02, 2012
    My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
    this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
    Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
    Roomba 4210 won't start
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle
    Dec 22, 2012 | iRobot Roomba 4210 Bagless Robotic Vacuum
    I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
    Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
    Irobot roomba 500
    If you're sure the battery contacts are clean and the battery really is charged, then there is faulty circuitry within the Roomba that would have to be repaired or replaced.
    Confirm that the battery is inserted with the metal contacts down so they make contact with the spring terminals in the battery compartment.
    Visually confirm that the metal contact plates on the battery pack, and the spring terminals in the battery compartment are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
    Visually confirm that the metal contact plates on the Roomba, and the spring terminals on the docking station's home plate are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
    If you have a volmeter, measure the voltage between the contacts on the battery pack If it isn't something in the neighborhood of 14 volts and is 11 volts or less, the battery isn't fully charged.
    Reinstall the battery.
    For the moment, please connect the power adapter directly to the Roomba rather than the docking station to eliminate one possible faultly connection.
    If the battery wasn't fully charged, or you weren't able to test it, try to charge the Roomba and then retest the battery voltage if you can. If the battery voltage was higher immediately after charging, but didn't get to 14 volts, the charger is good, but battery needs to be replaced. If the battery voltage was unchanged after attempting to charge the Roomba, the charging circuitry may be faulty. If there was no light patterns when you tried to charge it, and it was plugged in to a good outlet, then the power adapter or charging circuitry is definitely bad.
    If you have no voltmeter and you cleaned the contacts and tried to charge the Roomba and it works, use the Roomba and then recharge using the docking station and see if it was just dirty contacts or it won't charge through the docking station. If it didn't work, you'll need to figure out if its the battery, the charging circuitry in the Roomba, or the power adapter. If there are no lights when you try to charge the Roomba, then Either the power adapter or the Roomba power circuitry is defective, but without a voltmeter you can't find out which one, and there's no way to know if the battery is good or bad, but you know Roomba wasn't trying to charge it. If there are lights when you try to charge the Roomba, then at least you know the power adapter is good. Unfortunately, without being able to test something there's no way to distinguish between a charger that won't deliver a charge to the battery and a battery that won't accept a charge. If you want to take a guess then a bad battery is more common and less expensive to fix.
    Jul 07, 2012 | iRobot Roomba 560 Robotic Vacuum
    My dirt devil model bd10025w won;t recharge when plugged in and won'yt woek when plugged in
    Assuming that you've tried a different electrical outlet, it may have a defective charger or a totally dead rechargeable battery.
    Try Dirt Devil's customer help line:
    1-800-321-1134.
    Good luck from Detroit, MI.
    Jul 18, 2011 | Vacuums
    I bought Dyson DC16 in 2008. Charged full but it only last for 1 minuet. Should I get a new charger? Is Dyson going to send me a new charger?
    Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
    We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
    Shorting the battery like an Aircraft battery then re-charging won't fix it.
    Jun 09, 2011 | Dyson DC16 Root 6 Bagless Handheld...
    My Dyson DC16 usually shuts down after about 5 to 10 seconds. However, occasionally it will run for 45 seconds to 1 minute before shutting down. It is left on charge permanently. I have checked the...
    Mar 23, 2011 | Dyson DC16 Root 6 Bagless Handheld...
    Handle release catch out of place.
    I just took mine apart, and there is rounded grooves on both sides of the base for the upright section to rest in. When I put it back together, it naturally pulled out of those grooves and laid back flat. I had to hold it in the grooves while reattaching the screws. The piece that comes off and allows the upright enough movement to come out of the grooves is on the top of the base in the back middle. There is one screw on the front of it, and then 4 screws in the back of it. If your upright section appears to be not in the grooves, remove those five screws, place it in the grooves (it'll have to be slightly elevated---can't lay it all the way flat or it'll come out) and reattach the screws.
    May 06, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
    Is not charging - no red light
    Yes, it can be replaced. Can be ordered from Black & Decker. Some people would say it's worth fixing others would not. Don't know cost of battery -- probably under $20.
    Apr 29, 2009 | Black & Decker CHV9600 Handheld Vacuum
    Vacuums Logo
    27 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
