Rockola 484 sometimes picks up the wrong record, usually it picks up the correct one but not always, the unit is set on free play Any ideas how to fix Thanks scott
SOURCE: Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Posted on Nov 25, 2008
freetek
  • 5568 Answers
SOURCE: Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Posted on Sep 07, 2009
  • 1138 Answers
SOURCE: I have a Rockola jukebox model 456.It worked well
You might want to try this forum:http://www.antiqueradios.com/forums/viewtopic.php?t=104054&highlight=&sid=231c6e27ef15ccbe83c7a412bb9c8b86 The part in the post about lubrication is important but might not be the solution to your problem. I would suggest joining and posting as there is probably other owners who are members.
Posted on Mar 27, 2010
cnavarro
  • 2460 Answers
SOURCE: ROCKOLA 480 HUMMING NOISE IN
Wow. This is a tough question to answer because it may have no answer. Listen to Alabama's Jukebox in my mind. Is that the hum you hear? It's why it's a jukebox. I have a replica that plays MP3 CD's and it's an option you can select.
If you have a sound when the needle hits the record, I'm not sure there is a fix for that.
Carl
Posted on Oct 31, 2010
SOURCE: How do you set the Rockola 480 to free play?
For free play on Rock-Ola 480. Open your jukebox, on the right,you will see a large metal box marked Profit Setter. In this box are Sections A, B and D. In section D, you will see very small white buttons on a pink background. Push ALL of the buttons in section D to the left with a pen.It will play for free until changed. For money, put it back like it was. It will also play all songs automatically. If you wanna know that, e-mail to varnett1@woh.rr.com
Posted on Sep 23, 2011
Hi I have a rockola 481 jukebox and when you turn it on a very loud deafening buzz constantly stays there ,if u play a record the overload light comes on. Dave
Can be from some mechanical parts, like small electromotors. Or from the supply power frecquency passing audio filters. Usually, changing condensers in power supply unit fix the problem.
Sep 10, 2017 | The Audio Players & Recorders
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
My rockola 424 turns but wont play
Are all the gears at the base of the gripper arm free to travel their full distance?
Aug 20, 2014 | Audio Players & Recorders
Adjust tone arm
Usually there is a hole towards the back of where the tonearm is mounted that adjusts the set down area. Be aware that some have two holes one for set down and one for pick up of tonearm. These can be adjusted with a flat blade screwdriver. Check and see with a good flashlight. Adjust slowly and check to make sure you are turning it in the correct direction.
Apr 04, 2014 | RCA Audio Players & Recorders
Rockola jukebox keypad doesnt work
If the whole panel is out it sounds like a missing or bad ribbon cable. start there and tell us what happens.
Nov 21, 2013 | Neonetics Rockola Jukebox Neon Clock
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
