Question about Ricoh Aficio SP C242SF - multifunction fax / copier / printer / scanner color
How to reset aficio sp c 242 - Ricoh Aficio SP C242SF
  • 417 Answers
SOURCE: error code 0-09
Hi there I can only find in the service manual 6-09 and 9-09 I will attach the reasons for both if they are of any help great if not there are no tech bulletins for this machine that says otherwise.
Thanks J
9-09 Paper jam in the fusing exit
If the problem persists, replace the FCU.
6-09 G3 ECM - ERR received Check for a noisy line.
Adjust the Tx levels of the communicating
See code 6-05.
6-05 G3 ECM - facsimile data
frame not received within
18 s of CFR, but there was
no line fail
Check the line connection.
Check connections from the NCU to the FCU.
Check for a bad line or defective remote terminal.
Replace the FCU, FCU or NCU.
Try adjusting the rx cable equalizer
Cross reference
Rx cable equalizer - G3 Switch 07 (PSTN), G3
Switch 08 (PABX)
Posted on Jan 06, 2008
  • 37 Answers
SOURCE: how to reset the RICOH
What do you want to reset ? is it giving you a service code ?
Posted on Aug 14, 2008
SOURCE: Have a Ricoh Aficio 3025
Posted on Nov 07, 2008
  • 30 Answers
SOURCE: Ricoh aficio 1232c. The registration
you need a new registration clutch then probably part number is AX20 0240 i believe but if the reg clutch is faulty i would usually replace all feed clutches at the same time other part numbers are AX20 0239 relay clutch x 2 and AX20 0224 feed clutch x 2
Posted on Nov 27, 2008
  • 86 Answers
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
Service manual for Ricoh Aficio SP 5200 DN with all parts and troubleshooting
go to service mode.
press up and down button. then press ok. go to SP5810 and reset.
Jan 29, 2017 | Ricoh Aficio SP 5200 DN Laser Printer
Aficio spc242 service call sc543
There may still be small fragments of the paper jammed in the machines roller system that you might be able to get to.
At worsethe roller has teeth busted on the gears and pulleys.
Aug 03, 2014 | Ricoh Aficio SP-C242SF - 21 PPM Flatbed...
How do I factory reset my Ricoh Aficio SP C811DN?
Go into SP mode. Saw it there once when I was just fooling around in SP modes at work. Enter SP mode with pressing the yellow clear all button, then 107 and holding down the red stop button. .
Jul 17, 2014 | Ricoh Aficio SP C811DN Laser Printer
press the up/down arrows together for @ 5 seconds, then hit "ok".
scroll to "engine"
look for 5-810 -SC reset, hit "OK" turn machine off/on using toggle switch.
May 09, 2014 | Ricoh Aficio SP C411DN Laser Printer
How to reset error code ricoh sp c242sf
Nov 15, 2013 | Ricoh Aficio SP C242SF
The Aficio SP C410DN is compatible with these other printer models:
- Aficio SP C411DN
- Aficio SP C400DN
It is also similar to the Aficio CL4000, but some of the parts may be different.
Sep 02, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C242SF - multifunction  fax / copier / printer / scanner   color Logo
181 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
