Question about Epson WorkForce WF-4630 Wireless Color All-in-One Inkjet Printer
Why will Epson 4630 not pull 4x6 photo paper from rear feed. I keep getting message to use main paper tray-- which does not take 4x6.
SOURCE: epson r2400 won't feed paper
I had the same problem, then found these instructions for cleaning the feed roller: http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf I used the paper towel method and it's working fine now with no issues.
Posted on Mar 06, 2009
SOURCE: paper doesn't always feed, and when it does, the paper rolls through without printing
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
Posted on Jun 01, 2009
aicaxz
  • 511 Answers
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Posted on Jun 26, 2009
asabur
  • 102 Answers
SOURCE: Epson Photo Stylus R300 paper error
Please replace holder shaft & Roller ******
Sk. Abdus Sabur
Posted on Jan 03, 2010
Testimonial: "many thanks for your reply - looks like is could be expensive (more expensive than replacing the printer?) i'll take it to an epson repair center"
SOURCE: Epson Stylus Photo R350 giving a paper jam error message
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
Posted on Feb 20, 2010
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
Keeps saying paper cassette no set correctly or objects blocking path
I was also stuck with this error message for a while. It turned out to be a 4x6 photo paper got stuck in back in a place that was not easily visible. I had to detach the double-sided paper module from the back, tilt the printer on its side and reach in with fingers and pliers to pull it out. The error message was correct, that something was blocking the cassette tray even though you could push the tray all the way in!
Jan 31, 2012 | Epson Artisan 800 All-In-One InkJet...
4x6 photo paper won't feed into printer after I put paper in the tray it says to put glossy side down and I have done that. Do I need to clean a roller or something?
Click on "File" then click on "Print" in the dropdown
In the Print window click on "Paper/Quality" then change "Main Tray" to "Photo Tray"
Apr 07, 2011 | HP Photosmart C8180 All-in-One InkJet...
How to load 4X6 photo paper
hi
  • Turn on the Epson 875DC and the attached computer. Make sure the cable between the two devices is securely in place.
  • Step 2 Remove any paper that is in the printer's feeder tray. Place the 4x6 photo paper printable side up in the tray, with the support sheet at the bottom of the stack of photo paper. Adjust the paper guides so they are pressed against the margins of the paper.
  • Step 3 Open the photos to be printed in your computer software program of choice. When you are ready to print the photos, click on the "File" link at the top of the window, then choose "Print." Click on "Properties" and select "4x6" for the paper size and "Photo Paper" under the paper type. Click "OK" to close the "Properties" window, then click "OK" again to print the photos.
  • Jul 02, 2010 | Brother MFC255CW All-in-One InkJet Printer
    Misfeed from the rear tray. The rear tray feed is not working. When it tries to feed it bends the right corner of the paper and then I get a misfeed message. I can't use the printer to print 4x6 photos...
    there could be a teenie piece of paper stuck in the feed path causing this to happen, you have to visually inspect and ensure it is clear. Use plain paper to test.
    rollers may also contribute to problems with feeding paper its good you tried that too.
    lastly maybe the photo paper is too thick for that printer?
    Apr 11, 2017 | Canon PIXMA MX700 All-In-One InkJet...
    I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo...
    Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
    Dec 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Can't print on photo paper from iphoto
    When running a piece of photo paper through the printer you must first remove the stack of regular paper from the tray and run only one photo paper at a time. Thank you, Dana
    Oct 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
    HP Photosmart 3210xi All in one printer will not print 4x6 photos
    Have you processed many print jobs through this printer? if so, you might be needed a maintenance kit. the kit will include new rollers that will help pull the paper into the proper feed paths.
    Apr 30, 2008 | HP Photosmart 3210 Printer
    Hp photosmart d7160
    hp photosmart d7160
    how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
    Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
    Epson WorkForce WF-4630 Wireless Color All-in-One Inkjet Printer Logo
    137 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
