Question about Dishwashers
Impeller stuck runs fine, but impeller blade won't move. Cannot see any debris in chut.e
5 Suggested Answers
  • 437 Answers
SOURCE: blades on hedge trimmer stuck or not moving,
There is a pin in the gear that helps the blade move when the engine is running. That pin may be sheared off and may require a new gear.
Posted on Dec 05, 2009
  • 5370 Answers
SOURCE: The blades of my Echo
As you have already mentioned that bolts are checked and they are not tight, but still once again recheck the bolts.---------Give it a quick check, with the unit OFF PLEASE:------- Turn it upside down so you can see the blade bolt heads and the washers you should be able to move the washers with your fingers if you can't then that is the bolt(s) keeping your blades from moving.-----------Two things will cause the blade not to move. They are the clutch drum and the drive gear. Click the link below:--- Check the gear and clutch:--- ------------- The gear is in red and the clutch is blue. I recommend taking the trimmer apart and checking the teeth on both of theses parts. If the teeth are worn off you have found the problem.-------- This will help.Thanks.Helpmech.
Posted on Jul 20, 2011
  • 2341 Answers
SOURCE: how to access drain pump filter on he5t how do i
This tip i wrote covers how to get to and clean the drain pump filter
Posted on Sep 06, 2011
  • 8204 Answers
SOURCE: How to repair a snowblower impeller that is stuck. No debris in sight.
not sure if this link will help you out.
Posted on Dec 16, 2016
The blade is stuck
disingauge blades turn mower completly off check blades for debris as well as the rest of the deck and mowers moving parts and belt systems if debris found remove it
Jan 22, 2014 | Garden
Blades on craftsman 18HP won't come on
the belt will be on the mower deck awnd run to the pulley on the bottom of the motor.
Apr 29, 2017 | Craftsman Garden
I have a dw 734 brand new and while planing walnut it is leaving scratches on the board they are may be 1/32 deep. I have all ready flipped the blades and it worked fine for a few passes and started to do...
I can't imagine that the scratches are coming from the blade. If the blade was damaged, there would be nicks in the blade which would leave ridges sticking up from the board, not down into it. My guess is that the scratches are occurring on the bottom side of the board from debris. You should be able to easily verify this. If the scratch are coming from the top, then maybe you have debris stuck to the feed rollers, but those wouldn't be constant. You might also have some debris stuck on top, not on the blade or roller that is scratching. Run some pine through it to find the culprit. Good luck.
Feb 12, 2013 | Tools & Hardware - Others
Waterfall pump hums but won't pump
this sure sounds if the impeller is blocked and not being able to turn ,Dont let it run this way , can dammage motor of pump , remove intake cover (unplugged) and wash out with garden hose real well , see if impeller (black plastic blade) can turn with your finger (unplugged) , should move easy ! this might be an indacation of need for a filter on pump inlet !!!
Oct 14, 2012 | Little Giant Submersible Fountain Pump
Won't get dishes clean
Possible that the spraying arms are not working fine and there is less pressure on the pump. If so remove and clean the pump and check the spraying arms specially if the arms are not moving faster.Please check this link for tips to clean:
Mar 11, 2012 | Frigidaire FGBD2431K Builtin Dishwasher
Low pressure in filter after pump 5-10psi
This would indicate a problem on the suction side of the system. Make sure all the baskets are empty and clean. Debris stuck in the impeller will also cause this problem. You may be able to reach the impeller and clear the debris without taking the pump apart. Just make sure the pump is not going to start running while you have your fingers near the impeller.
Sep 03, 2011 | Pentair "Pentair" In Ground Pool Pump ...
While running the temp stays normal but if i get stuck in a traffic the temp stars raising really fast
You may have a problem with the fan clutch. Is the check engine light on? If it is, have the codes read to find out what the problem is.
Another possibility is a bad water pump impeller, a worn impeller won't move enough coolant to keep the temperature down.
Aug 13, 2011 | 2003 GMC Envoy
Light is on- wheels not moving so not cleaning pool...
Most of the time with these automatic pool cleaners, that is going to be the impeller. Check your impeller to make sure that it does not have debris that is clogging/jamming it. Also, check the front and rear wheel axles for debris. Leaves and other large items often get stuck and prevent proper function.
Jun 30, 2010 | Smartpool Dolphin Robo - Kleen Above...
Calypso washer runs fine until 7 minutes, then stays stuck on 7 minutes until it finally gets a LD or Long Drain error.
Check the drain line for kinks or obstructions and check the pump. It isn't just whether the water drained, but how quickly it drained as well. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure that nothing is clogging the pump like that occasional stray sock, etc., and check the pump impeller. Make sure there are no broken or missing blades and that the impeller spins freely. If there are any broken/missing blades or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Oct 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Motor not running?
There is a pump motor underneath with an impeller that is most likely stuck. You will need to turn the impeller until it breaks loose if it is stuck. This is a common problem with GE dishwashers and I recommend that you run it at least once or twice a week to avoid this problem in the future, even if you have to run it empty.
Feb 27, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
