Hello My model GW-2078 turns on with heat and blower but the rotating flicker that creates the flame look doesn't work
3 Suggested Answers
  • 6 Answers
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
Posted on Dec 05, 2009
  • 3253 Answers
SOURCE: I have a York Diamond 80 Model P2MPD16N09601G. The blower comes on but no flames. I checked the igniter assembly and it wasn't heating up, so I replaced it since this has worked in the past. It st
try jumping out the pressure switch see if this works
Posted on Oct 07, 2012
I NEED GW-2078 electric fireplace remote please
Fixya doe not sell electric fireplace remote controls.
Mar 01, 2018 | Heating & Cooling
The light inside is burned out do we need a new insert
sorry but we have no idea what you have so we can not guess SORRY
Jan 07, 2018 | The Computers & Internet
GW-2078, makes a high pitch noise when fan is running, how can this be corrected, other than that it works fine
Without me physically hearing the noise I can't be certain but it sounds like a bad bearing from what you described. I would try spraying a little WD-40 or some type of lube. If that doesn't work then the fan motor may have to be replaced.
Jan 03, 2015 | Cars & Trucks
Model GW-2078 has stop working will not turn on
Its probably a safety switch has tripped on the inside
Nov 01, 2012 | Heating & Cooling
FEBO fireplace, GW2078 anyone have a website or number????
Not a solution, but a problem. I bought a 2078 from Big Lots 2mo. ago. Friday night, nothing. Checked plugin breakers, etc. Finally disaasmblrd the entire thing and checked every led,circuit, etc, and found nothing out of place or burnt. Now What? Taking it back to Big Lots today in a million pieces. Hope they can take a joke. Really like the outfit but need it to work.
Sep 19, 2011 | Heating & Cooling
Goodman model PGB036075-1B will start the gas and the burner but will shut down before blowing heat. Is it a bad switch?
Hello, sounds like either a dirty flame sensor or open limit switch. First try cleaning the flame sensor by turning power off to the furnace and using some steel wool. If the flame sensor checks out good then you limit switch is opening becuase of lack of airflow. check air filter, clean blower wheel, and check to make sure the blower wheel is running at proper speed and not dragging sometimes cause by a weak capacitor.
Mar 06, 2011 | Goodman Heating & Cooling
Flame does not flicke in my electric fireplace
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Nov 28, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
