Question about Cell Phones
I CANT MAKE OUT GOING CALLS DISPLAY SAYS REORDER TONE
What does reorder tone mean?
A busy tone (Busy Signal) and a reorder tone are two similar on-off repeating tones that differ in the spped that they beep on and off. Some lay terms for a reorder tone is a Fast Busy tone. Both types of tones use two different frequency tones simultaneously, 480 and 620 Hz, for the beep sound. Busy tones are a half second of tone and a half second of silence, repeated. Today's reorder tone is a quarter second of tone and a quarter second of silence repeated, twice as fast as a busy; a long time ago the cadence was a little different.
May 05, 2014 | Panasonic KXDT343 Phone
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
I have a call back on my answer machine but the red light wont go off it comes up with reorder tone I cant retrieve any of my messages I need help?
Press the message button and this will probably ring another extension this must be answered and the light will go out Or Dial *790 This will clear all local settings including call forward To set call forward on busy no answer dial *7105 (destination number) #
Nov 01, 2013 | Panasonic KXDT321 Phone
Reorder tone
This is a number being called that does not exist , if it is a programmed button try reprogramming it
Nov 01, 2013 | Panasonic KXDT333 Phone
How do I add my own message tone to phone , I have had the tone sent to me via blue tooth but cant work out how to select and add it as message tone . can only find ring tone , alarm tone and caller tone.
Step1: Click on "applications", then select "My files" Create a folder in the root menu and call it "media"
2. Click on media then create another folder and call it "audio"
3. Click on audio to enter then create the final folder and call it "notifiations"
4. When you have done this transfer your message tones to notification folders
5. Go to message,setting,select ring tones and you will see your files
Hope it helps.
Jun 08, 2011 | Samsung Galaxy S GTI9000 Smartphone
Cant change message tone on my sony eririsson mini xperia
The SD card has a folder named media, there is a sub-folder called audio, and subfolder to that is another called notifications. I believe you can also create ringtones and alarm subfolders below audio as well.
In the notifications folder place your new message tone.
To select the tone, choose settings, sound & display,Notification ringtone and pick your new sound.
Oct 03, 2010 | Sony Ericsson XPERIA X10 Cell Phone
When anserwing a call the phone beeps repeting
go to communication an go to call drop tone or service tone sumthang like that an turn it off
Dec 17, 2009 | Nokia 5800 XpressMusic Smartphone
My screen is blank..still can make calls but cant see my screen? i cant see who calls,cant see txt messeges..its just blank as if it was off..wat can ido to fix it?
To help you with this problem, I want you to know that when a cellphone got fell, the main problem will be make is lost in display,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD of display connection is only misaligned. Get it to the nearest cellphone repair center to get cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem. Hope this could help. Don't forget to say thanks..:-)
Oct 25, 2009 | Motorola Mobility Hint QA30 Cell Phone
Conference Calls/Transfer
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
May 21, 2008 | NorStar Meridian M7310 Phone
Fax is on pulse dial
Go to the Utility menu, select "Administrator Settings" (password required) from there , fax settings, telephone line. In here you should be able to set the dialing method. There should only be 2 options, just pick the other one. (PB is for tone i believe)
Oct 31, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
