Where is the menu button on free sat remote control.?
I can get all the Tv channels but cant get any on demand?
techman
  • 3130 Answers
SOURCE: remote control no longer works
an original remotes available for ya at http://www.remotes.com for 30 bucks + shipping
Posted on Apr 23, 2006
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
CheriT Dish
  • 146 Answers
SOURCE: My dishnetwork remote control 1 doesn't work. It
    • All DISH Network IR remotes
1. Goto System Info screen. You can enter the system info screen by either pressingthe system info button on the front of the DISH receiver box or by pressing thepower button once then the up arrow on the front of the receiver. If theseoptions are unsuccessful you can also open the smart card door on the front leftside of the receiver and pull out the smart card. 2. Onceyou are on the system info screen, hold down the SAT button until all modelights light up. 3. Entera number between 1 and 15 using the numeric keypad on the remote. 4. Pressthe pound (#) button 5. Oncethe SAT button blinks three times, press record. Note: If successful the number selected in step 3 willappear in the System Info screen under Remote Address.
Posted on Dec 30, 2010
SOURCE: Couln't initially set up my LUXOR combi TV/
You need to change the source to DTV and then press MENU ... go to the INSTALL tab and select First Time Installation
Posted on Jan 18, 2011
Tv says receiver is not on and do not respond to remote control
Hi Jackiewes928, I apologize for the inconvenience you have experienced. It is my pleasure to assist you today. I understand that the only channel you are currently getting is channel 116 and that your remote is not responding. Do any buttons at the top light up on the remote when you try to change channels? If so, what button lights up in red or green? if any button other the SAT button lights up this means that the remote is not on SAT mode and this would be why is not responding. In order to put the remote in SAT mode press the SAT button for 3 seconds. Once you do this try using the remote. If you need further assistance please feel free to reach me directly at kimberly.escobar@dish.com
Feb 06, 2013 | DISH Network IR Remote Control
No remote. How do I reset the menu or channel programming? Using sat box, but can't get the TV to channel 3.
You best bet really is to locate an original and not a universal remote for the set
Apr 08, 2012 | Televison & Video
The tv is jammed. Remote is fine but have pressed the wrong button
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
Oct 01, 2010 | DISH Network IR Remote Control
Can't change the channels
Whenever a remote is not working to change channels thefirst thing to check is the batteries. Even if some buttons on the remote areworking, it is possible that low batteries are the cause of not being able tochange the channel. Once the remote has fresh batteries, you'll want to makesure that the remote is in the correct mode. This can be done simply bypressing the 'SAT' button and it should light up. The next thing to do isre-address the remote to the receiver. First, press the 'system info' button onthe receiver (or access system info through the menu). Once the system infoscreen is showing on the TV press the 'SAT' button once and release then pressthe record button. The remote should then be working with the receiver.
Kaia S
DISH Network
May 20, 2010 | DISH Network IR Remote Control
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
I can't change the channels on the tv with remote or on tv controls. The channel up button on the tv only goes to channel 1 or aux. I need channel 73 to use satellite service. We have changed batteries in...
You will need to rescan for channals, or manually enter the number. Make sure your sat. box is on when you do this. Rescan can be found in your tv.s menu.
Jul 03, 2009 | Emerson EWF2704 TV
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Jul 01, 2007 | RCA RCR450 Remote Control
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
