Question about Poulan Garden
How do I unlock the rear wheels, I got a Poulan Riding Mower from a late Uncle. It won't roll forward or backwards
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Poulan Master
  • 939 Answers
Kevin, if it is in neutral or if it is hydro-stat, you have pulled the pins in the back to unlock the axles. the brakes may be locked up. the last two mowers i got for some reason the brakes were locked up on them both. hope this helps.
Posted on Dec 16, 2016
Testimonial: "HOW DO I LOCK THE BRAKES?????"
Won't move forward or backwards
Check the manual bypass for the transmission which allows the mower to free wheel. The manual bypass control lever is generally located at the rear of the riding mower.
Mar 13, 2016 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Drive wheels won't freewheel when pulling mower backwards,
pull off what looks like hub caps and check the wheel clutches
Apr 02, 2012 | Garden
I removed, re-inflated and reinstalled back right tire on my Poulan 42", 18 hpr riding mower, now it won't engage in gears and move forward or backward. I've compared the reinstallion with...
there is a slot on the axle for a square key to fit in.
when you took off the wheel it might have fallin off.
look around for a little square piece of metal.
like a little bar.
put it in the slot and put wheel back on.
don't forget to vote for me.
thanks
Jul 16, 2011 | Garden
Mtd mower will not move forward or backward.rear wheels won't move. When I lift mower up,rear wheels move opposite directions...
OPPISITE MOVEMENT IS STANDARD W/OUT TENSION,SOUNDS LIKE TRANS IS GOING OUT.HOW OLDIS YOUR MOWER?
May 01, 2009 | Garden
Rear wheels will not turn. Worked fine when stored for the winter
Craftsman-Husky...same tractors-built in the same factory. I also had a problem with the hydrostatic transmission not providing power to the rear wheels. Here's what Sears told me:
(1) Check to make sure the drive belt is tight both under the engine-and the tranny.
(2) Air can get into the hydrostatic transmissions-especially during shipping (new mower) and storage.
So.....
Pull your freewheel pin out to disengage the tranny-then push the mower both forward and then backwards for 50' or so. Then push the freewheel pin back in and start the mower. If the transmission then works-drive forward-then backward-then forward repeating the cycle about 4 times. Drive about 50' in each direction. This should purge the air from the treansmission.
Mar 20, 2009 | Craftsman Garden
Garden Logo
57 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
