Question about Vizio Televison & Video
How do i change the hdmi resolution on my Vizio tv
  • 135 Answers
If it is a television you cannot change the resolution. If it was a computer monitor you can change the resolution.
Posted on Dec 16, 2016
Hi I have acer laptop, I have a cable one end is hdmi and the other side rgb, is there a down load driver so it will work. thank you
If you're trying to display output from the laptop to the Vizio you'd be better off using an HDMI to HDMI cable. The VGA port on the Vizio E320 only supports 640x480 resolution; you have to set your display output accordingly, usually in control panel. Using HDMI you're able to keep the signal HD, @720p. The E320 also supports 1080i, but you're not going to see all 1080 lines. If for some reason you're trying to go from the Vizio to the laptop it just doesn't work that way.
Jun 24, 2014 | Vizio E320VP 32" LCD TV
I plug my HP 2000 notebook into living room Vizio TV with HDMI cable, and no problems, the Vizio becomes the PC monitor. I plug into the bedroom TV (RCA) with same HDMI cable, and I get an UNSUPPORTED...
It's a resolution issue before you connect to your rca tv drop your resolution down on your computer and see if you can get a signal. When you connect the hdmi cable it should automatically adjust the resolution but sometimes it don't.
Thanks for your question sure hope it helps if not don't be afraid to ask for more help.
May 19, 2014 | Televison & Video
Vizio m230vt Cannot adjust picture settings in custom on a pc
On the computer itself is where you would change the video resolution and additional settings
Your graphics card if Nvidia or ATI should have it's own display properties, settings.
Nov 15, 2013 | Vizio Televison & Video
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
TV is own and I here the sound, but there is no picture. TV is a vizio HDMI HDtv 32 inch
First make certain that the HDMI is pushed into the TV all the way. Also it depends on what your source is and how you have it connected. You could be using an HDMI cable with your cable box, and the cable box could be defective. It could be a DVD player and HDMI video may be disabled. If you are just using HDMI directly from a cable box to your TV and you have audio, but no video, then perhaps the resolution is set incorrectly on the cable box - which means it's a cable box issue that you need to set your resolution to something standard, like 1080i.
Or, perhaps the HDMI cable is of lousy quality, in which case, you should pick up a new hdmi cable from a place like for not a lot of cash.
Please get back to us if you have further query or else please accept the solution.
Sep 12, 2011 | Vizio Televison & Video
My Vizio (VA26LHDTV10T) Tv says "Not support" when I plug up my Xbox 360 to it with an HDMI cable.
You get this issue because the TV does not support the resolution your xbox is displaying at. I had the same problem with my PC since I use the TV as a monitor. The TV will do a max resolution of 1360x768 so, you need to set your xbox to that resolution or the one closest to it as long as it is under that number.
Aug 22, 2010 | Vizio VW32L 32 in. LCD HDTV
I changed my HDMI cables to get my PS3 to play
You need to set your HDMI, resolution down, on PS3 FIRST, using composite, or component hookup, to the TV FIRST, Turn OFF, but DO NOT select HDMI, leave it on, Composite, or Component, when finished setup the TV, the turn it off, leave off, Then connect up PS3, power on, NOW turn on the TV, select HDMI, Change PS3 to HDIM, now it should appear. Sometimes you have to "Reset" the TV, by tuning it on & off.
Apr 24, 2010 | Vizio L32 32 in. LCD HDTV
How to adjust from 480p to higher resolution up to 1080
several things use hdmi cabling, also change resolution (can sometimes be changed on front of direct tv receiver) or may have to go through menu to change to the different resolutions. also turn the native mode OFF! having the native mode on for directv will give sometimes give you odd pictures. also whatever resolution you choose through directv menu's make sure your tv is also set to the same resolution
Apr 04, 2009 | Televison & Video
Eed help connecting MacBook Pro to Vizio VP50HDTV
I would say this is a resolution issue. The LCD on your MAC is capable of a much higher resolution than your television. To mirror your MAC you must lower the resolution to something that is at or below the televisions native resolution. The native resolution of the VP50 is 1366x768 so you will be able to do the following resolutions: 640x480, 800x600, 1024x768 and 1366x768.
Apr 04, 2009 | Vizio VP50 10A 50 in. Plasma TV
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
