Question about Cell Phones
Add an contact number - Cell Phones
  • kakima Dec 16, 2016
    Hi Janet Fitch, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    To what make and model phone?
How to add contacts in a apple 5s
1. Simply tap Keypad, output a phone number, then tap on the + button at the top-left.
2. After popping up a window, you can select "Create New Contact" or "Add to Existing Contact".
Jul 21, 2017 | Apple Cell Phones
How do I add more than one phone number and email address to existing contacts on my Samsung Galaxy J1 mini?
there is something in it called edit under options . or try writing down the name number(s) you want then delete the first entry and then add NEW CONTACT
Jun 24, 2016 | Samsung Cell Phones
How do I enter contacts and their phone numbers
Hi Joseph
Add a New Contact
Step 1 Touch the "Main Menu" soft key on your LG phone, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option to access a menu that allows you to add a new contact. Select the "New Contact" option using the soft key or directional keys. This action opens a blank contact template.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Add the contact name in the same manner. Touch or select "Save" to complete the addition of the new contact.
Add a New Number to an Existing Contact
Step 1 Touch the "Main Menu" soft key, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option. Scroll through your contact list and select an existing contact to whom you want to add a number. Touch or select the "Edit" option.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Edit the contact name in the same manner if desired. Touch or select "Save" to save the new number under the existing contact.
Apr 18, 2016 | LG Cell Phones
How do I add a contact
How do I Create, Delete, Edit, and Manage the Contacts on ...
www.samsung.com > ... > More Cell Phone Providers
Samsung ElectronicsHow do I Create, Delete, Edit, and Manage the Contacts on my Samsung Galaxy S4? ... Other, Callback, or Custom by touching the label field (by default, this will showMobile). Touch to add more phone number fields, or touch to delete a field.
How to Add Contacts Manually on Your Samsung Galaxy S 4
www.dummies.com/.../how-to-add-contacts-manually-on-your-samsung-...
Adding contacts manually to your Samsung Galaxy S 4 involves taking an existing ...If you want to add a second telephone number, tap the little green plus sign, ..
Jan 08, 2016 | Samsung Cell Phones
Nokia lumia how to add contacts?
Follow these instructions to add new contacts on your Nokia Lumia
  • On Start, swipe across and tap People.
  • Tap the New icon (+) at the bottom.
  • Tap Name to add First name, Surname, Title, Company name etc then tapSave.
  • Tap Phone to add a contact number and tap Phone number type to choose the type of number then tap Save.
    If you wish to add further information such as an additional phone number or an email address, tap to add more details or press Save to store the contact to the People Hub.
May 05, 2014 | Cell Phones
How do you store a number
After you dial or receive a call, go to your recent calls. High light the number you want to add and access the drop down menu, it should give you the option to save the number or add a new contact. Or you could go to your contacts, or people, or where ever your contacts are and add new contact.
May 03, 2011 | Cell Phones
Nokia E71 - Saving new contact
check your phone memory limit may be it is full.
if it is still empty u need to reset all settingms of your cell phone to factory defaults.
Go to setttings then reset your celll phone.
but i think your cellular limit is over for save new contact check it .
Apr 05, 2009 | Nokia Cell Phones
I want to program a new number into my old A900 Samsung phone to replace my wife's old phone.
Hi
Surprsingly u never mentioned the name of the network which u r using. Please mention the CDMA server's name.
Thanks.
Supriyo DG
Jun 19, 2008 | Cell Phones
I can't add more than 1 phone number per contact
Try this:
- type in your number
- select options
- select Save to
- select Existing Contact
- Select your contact from existing list
May 21, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Samsung d900i
Create contact (Menu 2.3)
Use this menu to add a new contact to Phonebook.
Storing a number in the phone’s memory
1. Select Phone.
2. Change the settings or enter information about the
contact:
First name/Last name: assign a name.
Mobile/Home/Office/Fax/Other: add a
number in any category.
You can change the number type, or set the
number as the default for the contact by
pressing <Options> and selecting Change
type
or Mark as default number.
Email: assign an e-mail address.
Graphic ID: assign a caller ID image to alert
you to a call from the person.
Ringtone: assign a ringtone to alert you to a
Group: assign the number to a caller group.
Birthday: enter the person’s birthday.
Notes: add a memo about the person.
3. Press <Save> or [ ] to save the contact.
Storing a number on the SIM card
1. Select SIM.
2. Select New or Update.
3. Enter information about the contact:
Name: assign a name.
Phone number: add a number.
4. Press <Save> or [ ] to save the contact.
Mar 05, 2008 | Samsung SGH-D900 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
