Question about Home Security
Some one cut the wire coming out the back of my swann SWPRO-642CAM security camera and need to repair it.
The wire is cut about 12" from the camera and the end has 2 red 2 black 1 yellow 1 gray and 1 brown how can i repair please help
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
TBlessed 1
  • 61 Answers
SOURCE: ceiling fan wires
is the old fixture still installed?
Posted on Oct 17, 2008
bunnydawg
  • 5158 Answers
SOURCE: memory not working
blue yellow to yellow and gray to red should be right
Posted on Feb 01, 2009
smartr10U
  • 1305 Answers
SOURCE: need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
Posted on May 31, 2009
  • 17 Answers
SOURCE: o2 sensor wiring diagram
A new 02 sensor will come with new wires and connector. If not get back with me I think there is a repair kit for that problem.
Posted on Jun 01, 2009
Wiring repair diagram for swann SW-231 WCH WIRELESS CAMERA
Contact Swann and request a wiring or schematic diagram.
Nov 19, 2017 | SWANN Home Security
I have a security cam from swann that wires have been cut two reds two blacks and a yellow what connect to what
Both red are for Power Positive and both black are Power Negative.
Yellow is for Video output and connect video ground to the Black Wires.
Oct 08, 2016 | SWANN Home Security
I have a swann hd security cam and I need installation instructions and wiring diagram
Find the model number, then Google search for a manual. Serial numbers are of no use when troubleshooting electronics.
Jun 03, 2015 | SWANN Home Security
Need a wiring diagram for a Swann security camera model 642 3960 it has 9 wires what I cook the wire where the wires go do the wiring diagram
1) Turn the power off.
2) Remove the printer cover.
3) Remove the ink roller by turning it counterclockwise and
pulling it upward.
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place.
5) Put back the printer cover
Mar 06, 2015 | SWANN Home Security
WHAT IS THE WIRERING DIOGRAM FOR A SWANNS S/N 274540212130041 SECURITY CAMERA?
you have the part that broke you need to reattach is and it will work
Oct 15, 2014 | Swann Communications Home Security
I need help wiring a panasonic stereo in a 94 honda accord
Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger Yellow/White Antenna Left Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Mar 10, 2014 | Cars & Trucks
Home Security Logo
83 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
