Question about KitchenAid Blenders
My kitchenaid blender won't work. Lights for all the settings come on but motor won't start
  • KitchenAid Master
  • 1,231 Answers
I expect you will find that the motor is open circuit. There is a thermal fuse incorporated into one of the field windings which can be replaced with a bit of messing about. A job for a retired appliance service person if you want to keep the price down. Did one today, took about an hour from start to finish.
Posted on Dec 20, 2016
SOURCE: Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Posted on Nov 09, 2007
SOURCE: Need new glass container for kitchenaid blender.
They are usually in stock here:
http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
Posted on Jan 24, 2010
SOURCE: Blender died ...... motor won't turn on
It needs a new fuse (or atleast the worked for me)
Posted on Jul 09, 2010
SOURCE: Cuisinart BFP-703CH Chrome Blender does not start
I had the exact same problem with my Cuisinart bfp-703ch blender. When I plug it in, the lights come on but the motor wouldn't run. After reading some posts I almost decided to throw it away. But my brain started to itch and I gave it a shot anyway. I eventually found the problem to be with the Thermal fuse. If you overload/overheat the blender, this fuse is going to blow off.
To replace it, I opened the bottom panel and followed the wires that come from the circuit. Once of those wires eventually will lead to the thermal fuse. It may help you if you unscrew the circuit board. Then I detached the fuse with pliers, got a replacement thermal fuse from Radioshack and connected it back on. I also had to solder it to make sure the connection is more robust. And Voila!!! my motor started working again.
Posted on Dec 23, 2011
odiebugs
  • 949 Answers
SOURCE: Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Posted on Mar 31, 2013
KitchenAid Blender
The motor will probably be open circuit, take it back under guarantee and let them sort it out. If you mess around you will void your guarantee.
Aug 05, 2014 | KitchenAid Blenders
Problem with soup mate,all lights flashing but nothing happening
If this is a Kitchen Aid blender with the flashing lights then you will need to remove the motor base cover and check the motor for a circuit. If it is open circuit then either replace the motor or locate the thermal fuse (under some white tape and aluminium clip on one of the field windings) and either replace or bypass fuse if it is open circuit.
May 19, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Why the lights on my kitchen aid baking not coming on
Check for loose connections from mains cable to PCB and from PCB to motor. Check motor for circuit continuity, it may need a new motor, it is rarely the PCB.
Jul 26, 2013 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Kitchenaid blender motor loud hum not working
Can you check it without the beaker on? It could be the blade seizing up, how free does it turn by hand?
Dec 02, 2012 | KitchenAid KSB560 5 Speed Blender
How do you replace a bad circuit in Kitchenaid blender KSB50B4
It is more likely the motor is faulty than the circuit board. Test the motor with a meter.
Aug 12, 2012 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Ksb 560 mco 5 speed blender lights flicker a as soon as switched
My Blender Model number KSB560MCO does not run. When try to blend all of red lights come one and they blink and move around. Any suggestions what could be wrong? Appreciate any help.
Thanks
Jul 30, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
KitchenAid Blender KSB5WH3 flashing lights how to get to the fuse
i found broken solder connections on triac on circuit board. it's the part with the cooling fingers that surround it. pencil soldered the cracked connections; now works fine.
Jun 19, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
I have a Kitchenaid blender model KSB5BU3 marked "Ultrapower" and "Electronic Control" on the side. Suddenly all the buttons started blinking together after we pressed the On button and then one of the...
When the lights are flashing, this does indicate that an electronic part has failed. This blender is no longer manufactured, so finding replacement parts for it may not come easily. Repair centers are available. I would recommend calling Kitchenaid Customer Service to see what they can recommend for you.
Their toll-free number is 1-800-541-6390.
Jan 10, 2009 | KitchenAid KSB5 Ultra Power Work Top...
Blender won't work
This indicates an internal problem with the blender itself as pertaining to the motor. I would suggest contacting Kitchenaid Customer Service to see about having the blender repaired or possibly replaced.
Their toll-free phone number is 1-800-541-6390.
Also, a listing of Kitchenaid certified repair facilities may be found at the following link:
http://caservice.kitchenaid.com/
Sep 06, 2007 | KitchenAid KSB5CR Chrome 5 Speed Blender
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
Blenders Logo
258 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
