Question about Siemens Washing Machines
On my siemens washing mashin it apears f23 errer code?
5 Suggested Answers
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
  • 154 Answers
SOURCE: I have a siemens WM14S794GB washing machine and F23 is flashing
F:23 means that your machine is leaking and should be repaired. This is often a bad seal and if you are competent or know a friend who is they can inspect the source of the leak for you. Needless to say you should make sure that you unplug your machine before attempting any repairs.
Hope this helps you.
Posted on Jun 22, 2010
rickead1
  • 1998 Answers
SOURCE: I have a Siemens WM14S794GB
F-23 is an error due to an internal leak inside of your machine this is usually due to a bad seal between the inner and outter tub also if done by a technician a very costly repair in which they usually charge 4-600 for the repair itself includeing the parts. If you feel you are capable of doing the repair the parts are the inner and outter seal and sold as a kit usually for around 90-110 dollars and you can find the parts at www.marcone.com under contact us there is a 1800 number as well as an overseas number if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations when our chat has fully concluded Thanks Rick
Posted on Feb 21, 2011
gopakumarg43
  • 75169 Answers
SOURCE: Siemens front load washing machine. Stuck between door and the panel. Can't open the door. F23 appears.
https://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
Visit these sites to get some details.
Posted on Jun 09, 2016
Siemens front load washing machine. Cloth stuck between the door and the panel. Can't open the door. F23 appears.
the tub beneath the washer is full and is not draining. the clothes have probably opened up the seal between the door and washer allowing water to leak. tip the machine and empty the sump to clear error.
Jun 09, 2016 | Siemens Washing Machines
F:80. My new siemens washing mashine IQ700 shows F:80 at the end of the program with the alarm. I can\t open the door normal way. What does it mean? We installed the mashine yesterday.
It means that the machine register what's in there as too heavy.
Can't understand for the life of me why this error code isn't explained in the user guide, but that's just how it is.
To fix this, turn off the machine, make sure that you get out as much water as possible and then open the door manually by pulling the red plastic band to the right of the pump (remove lid first ofc), or you need a screwdriver or something like that on some models depending on the age of your product.
I do know that this answer comes a little too late, but browsing for answers myself, I had to dip into the old noggin of myself as a former White Goods Consultant and I figured it all out.
For future reference I therefor post it here anyway ;o)
Jun 23, 2012 | Siemens Washing Machines
F 23
The meaning of the code depends on the machine's manufacturer.
On Siemens built machines (Siemens, Electrolux, hotpoints etc.) F23 Means that there is overflow and anti flood device has been activated.
In this case:
Disconnect power.
Remove all water at the base of the machine.
Take off the rear panel, or access the drain pump from front door(depends on model).
Check drain hose height and check hose connected to drain pump.
Connect power back.
If problem does not clear after connecting back, replace pressure switch.
With Wirlpool built machines instead (Whirlpool, Maytag, Kenmore etc.) f23 means there is a communication within the CCU and the MCU.
CCU is the main control module (central control unit), and MCU is the Motor Control Unit. MCU is a sealed module located deep inside the appliance, and connected on one side to the motor, and on the other to the CCU. Testing F23 on a Whirlpool is more difficult and requires a technician. In this case all you can do is disconnecting power, if error does not go away call the service number listed on manual.
Regards.
Ginko
May 19, 2011 | Washing Machines
Sep 11, 2009 | Siemens WM14S794GB Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
