Propane tank top heater wont stay lit
When i hold the red button to light my tank top heater for the required time it always goes out even after i release it slowly Worked good last season only used a few times last year. Whats up?
  • Heating & Co... Master
  • 2,598 Answers
Try replacing the thermocouple , and clean pilot .
Posted on Dec 17, 2016
We bought a big buddy 2 days ago and now it wont work.
Push red button down to start, maybe 3 times, then push red button down HALF way down then turn to low.
IT COULD BE YOUR PROPANE TANK, got a new one but had problems, so I left it on all night and it lit in the morning.
BUT when I got it filled the next time the man said the stem in the tank might need to take it outside and bang the tank several times, stem in the top gets stuck a lot he said.
But last is to take the tank outside and use a flat head screwdriver and turn the screw? on the side where the hose would be connected to let some out.
Feb 05, 2015 | Mr. Heater Big Buddy Heater
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Table top propane heater: tank freezes, fire goes out
I have a table top heater and was wondering why I have flame shooting out of the top of it when I should have like a blue flame, what can I do
Dec 14, 2009 | RTO Bernzomatic Brushed Nickel Patio...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Water heater will not stay lit even after replacing thermal coupl
The pilot must encompass the thermocouple "bulb" in order for the thermocouple to generate enough current to keep the pilot valve on. You must also hold the red button down for a long enough period to get the thermocouple hot. If the pilot is not large enough, it could be due to a clog in the pilot orifice at the pilot itself. Sometimes a couple of passes over the end of it with fine steel wool is all it takes to clear it.
Hope this helps. Feel free to share what you found. Thanks.
Jul 16, 2009 | Kenmore Dryers
Tank-top propane unit won't stay lit
I had to replace the regulator. If you have a propane appliance shop near you, you can probably just get the nipple that goes into the bottle. It's aboit 3/16" diameter, 3/4" long and may have a 6 sided end up inside the screw on cap of the regulator.
Feb 24, 2009 | Mr. Heater Model MH12TS - Single Tank-top...
Propane heater wont work
I'm not sure about that model, but I think you have to hold that button down for a minute or more to "prime" it.
I have a different model coleman propane heater that sits on the 20# tank. Mine is probably getting rusty, last time I used it I had to hold that button down for a long time.
I'm looking for a new heater now myself, as mine won't stay lit outdoors in much wind.
Dec 22, 2008 | Heating & Cooling
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
