How to adjust fuel mixture propane rlp100 this unit burns my eyes and the fumes are bad
  • Heating & Co... Master
  • 2,458 Answers
It sounds like it needs a service if it is giving off fumes turn off and get it serviced asap
Posted on Dec 17, 2016
tinytrees
  • 92 Answers
SOURCE: fumes
One of two things, a high heat limit control or the flame sensor, also check your air line that runs to the heater nozzle could be cracked, not enoughair to fuel mix will make it burn dirty.
Posted on Jan 23, 2009
tbugger
  • 232 Answers
SOURCE: How can I adjust the pump screws to get less fumes?
www.reddyparts.com has instructions for setting the pump pressure.
Posted on Mar 09, 2009
  • 234 Answers
SOURCE: ive got a reddy heater pro 155 when you turn it on
Are you sure it is running too rich? Your eyes will also burn if it runs too lean because the hyrocarbon and nitrous oxide balance is off. If too rich, there usually is a smokey vapor that is emited, whereas too lean does not create any seeable vapor.
If youhave a little tech to you, you can over-ride the control board and have the power go directly to the burner (as is in the older burner models). If you get the same results, then you'll know itis not the control board. Goodluck,Macgivor
Posted on Oct 25, 2009
  • 5 Answers
SOURCE: After 10 minutes of running in uninsulated garage air becomes dif
I need more details... what is it doing, what is your supply, etc....and why do you think it is the very unlikely improper air gas mixture?
David Lawrence the Propane Fuel Dude
Posted on Dec 10, 2009
koolbreezes
  • 540 Answers
SOURCE: raw propane fumes and burning eyes
Ours didn,t burn liquid propane too well, so ccheck your connections on your tank for vapor or liquid.
Posted on Dec 18, 2009
I have a reddy heater 100 pro it stinks when it is going and burns my eyes
If you are using it inside, in an area that is not well ventilated, that is the problem. In addition, if this heater is in a work area and there are paint or stain fumes or anything similar, the heater is picking up those fumes and making them 100 times worse.
Also, is the heater has not been cleaned and service regularly, this also could cause the odor, due to incomplete combustion. Also, how old is the gas in the tank you're using. Old LP Gas can also cause the odors.
Those things listed above, are all things that can cause the problem you described. Resolving those should take care of the odor problem.
Feb 12, 2011 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
I have a rlp100 heater that works well but now has an annoying smell. It also burns your eyes some. It is 3 years old and hasn,t been used much. What can I do to get rid of the smell?
The smell is unburned propane and the burning of the eyes is caused by carbon monoxide. My heater (RLP100) does the same and I was able to measure the carbon monoxide at 95 ppm (deadly). I have yet to figure out what exactly is happening. Tried a new regulator/hose from a new unit - no help. Also pulled apart the burner nozzle and cleaned the holes - helped a bit. Next step is the valve.
Dec 18, 2010 | Reddy Heater RLP100 Portable Forced Air...
My heater worked fine for a few months last year before it started burning a smaller flame and not heating as well. I then started noticing the increase of propane used. It seems as if it is running rich ...
Check for an air filter....many of these heaters have an air filter that gets dirty or clogged and then they will do just what you are describing her....
also take an air hose and blow out everything....
What you have there is an air/fuel mixture problem...
you are not getting enough air to the burner... most like because of dirt...
The only other explanation would be that the blower is no longer running at full RPM's....
You could also try to get some oil on the shaft of the motor to lubricate it and get it running back to full speed again...
Check the fan blades for dirt also...
heatman101
Nov 27, 2010 | Reddy Heater RLP100 Portable Forced Air...
Propane 100,000btu heater runs fine but has a lot of fumes, it almost burns your eyes
Go to my tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters for all your answers. Your air fuel mixture is off. You need a new air filter and need to set the bleed air. For that you need special tools which you can get at the information I give at my tip. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 13, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
FLAME PROBLEM WITH REDDY HEATER RLP100, HAS BAD FUMES WITH LITTLE FLAME
Hi it sound like the burner /ports a blocked trycleaning them out should improve flame
Jan 17, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Raw propane fumes and burning eyes
Dec 17, 2009 | All-Pro Propane Garage Shop Heaters - All...
Dec 08, 2009 | Reddy Heater RLP100 Portable Forced Air...
Propane forced air heater
Need to make sure you are supplying a minimum tank supply of 100lb cyclinder. If smaller,you are producing co due to low gas flow
Nov 02, 2008 | Reddy Heater RLP100 Portable Forced Air...
Burning eyes, can't breathe.
These produce large amounts of carbon monoxide, so you essentially are poisoning yourself. Leave the garage door open part way when using it.
Feb 10, 2008 | Reddy Heater RLP100 Portable Forced Air...
Propane Reddy Heater
AIR MIXTURE ADJUSTMENT IS CRITICAL ON ALL GAS BURNING HEATERS. SOUNDS LIKE YOU HAVE INSUFFICIANT CUMBUSTION AIR WHICH WILL CAUSE A WHITE AND LAZY FLAME .... FLAME SHOULD BE BRIGHT BLUE WITH NO WHITE OR YELLOW TIPS ON THE FLAME.
Apr 06, 2007 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
