Do you know of any repair places to get my all products 115,000 btu unit fixed? I'm in Norwood mass
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have an All-Pro, 115,000
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 16, 2011
hardrocko
  • 1476 Answers
SOURCE: from: AJORTOLANI@FRONTIER.COM REDDY HEATER 115,000 BTU'S
ajortolani,
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, how to fix it and where to get the parts.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Posted on Jan 19, 2011
espressonist
  • 1711 Answers
SOURCE: Have a 115,000 BTU All-Pro
The price for a new one can be 300-400$ and for a used one from 100-200$
Here is an indication prices from diferent models and sizes
http://www.nextag.com/multi-fuel-heaters/compare-html
Posted on Aug 19, 2011
app_3rp82576
  • 3 Answers
SOURCE: 115,000 btu reddy heater, 5 hrs used in
I had the same problem, took off the cover noticed the fan was not rotating freely . I sprayed peanut butter blaster & poof problem solved.
Posted on Dec 29, 2012
115,000 btu reddy heater, 5 hrs used in sprayfoam-grinding environment. stopped working. when plugged in, only hums for a few seconds, then stops. how can i fix that?
First, remove the top cover. Inspect for a varmint nest. If clear, manually spin the fan. If it does not you either have a broken rotor that is binding or you have a bad bearing.
If it spins freely, apply power- see if the motor runs with the top cover removed.
If YES, replace the top cover. Its possible that the top is binding the fan.
If NO, the start capacitor is defective. The cap on R115 is internal and is not servicable.
Reading material about a hummer
Nov 04, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
My reddyheater115,000 was working just fine now it only hums when you plug it in HOW DO I FIX IT
the pump,is locked up,in the rear of the motor,or the motor has gone bad,I have a pdf file on this model if you need it,let me know,roniecon@gmail.com
Mar 31, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
From: AJORTOLANI@FRONTIER.COM REDDY HEATER 115,000 BTU'S DUEL FUEL (RUNNING ON DESIEL) UNIT RUNS FOR A FUE MINS. THEN LAGRE PUFF OF SMOKE IS RELEASED AND THE UNIT NEEDS TO BE UNPLUGED TO START IT...
ajortolani,
hardrocko
Jan 19, 2011 | Reddy Heating & Cooling
Reddy heater115000 motor seems to lock up I take the pump off and put it back on than the motor spins freely and unit runs 5 or 10 minis or so than locks up again
you have to replace the pump yearly it gets brittle and leaves a residue on the housing. clean the housing with a carb cleaner and then polish with an aluminum polish and that should fix the problem.
Dec 22, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Is there supposed to be flame coming around the cone of a 115,000 btu reddy forced air kerosne heater?
no. the flame should be behind the cone. If it passes the cone, this means that there is too much air. simply turn the air pressure screw until the flame no longer comes beyond the cone.
Nov 27, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Reddy heater error message c3
See my tip at http://fixya.com/support/r4124129-yearly_maintenance_reddy_heaters A website for parts plus why your unit is not working is listed. Let me know if you need anymore help.
hardrocko
Feb 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
I changed filters,but still get eye burning smell,I do use Kerosene
In my experience, eye burning is a by product of burning even the best kero. And at 115,000, you are burning a lot.
Jan 03, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
My Reddy heater does not run. How do I know what
i have a 115reddy heater it run for 3or4 mins then it shut off and blue some comes out what causing that
Dec 02, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
