Comfort control not working
The furnace comes on at the programmed time instead of having the house up to the desired temperature at the programed time.
    Master:
  • 946 Answers
Set it to come on one hour earlier. don-ohio
Posted on Dec 31, 2016
Where is.the battery on the comfort zone II
There may not be a battery, it may run off the 24VAC from the furnace/ac control transformer.
In the FAQ one of the questions is:
What if my power goes out, will I lose my program?
The answer:
No, However it is recommended that you record your program schedule...
It makes no mention of any battery keeping the memory.
Aug 03, 2016 | Comfort Zone Heating & Cooling
I'm having a problem with a digital t-stat
It may be a wiring problem at the thermostat, quite often there is a jumper missing in the thermostat between the R terminal and the RC terminal. hope this helps
Jun 12, 2014 | Dometic Rooftop RV Air Conditioner
Thermostat is heating house to desired temp before programmed time
there is a installer setup in this thermostat. do you still have the book?
you will need to gain access to the installer setup/programming and in it you will find a setting called auto recovery turn it off. what this does is after a few days of initally running the system figured out it needed to come on earlier and is starting before the set time to come on... you can turn it off and then will have to adjust depending on insulation value/construction type of home how soon you want it to come on so that it reaches desired temperature when you want...
hope this helps you out,,,
Nov 21, 2011 | Honeywell Programmable Thermostat Heater
Hi. I am just wanting to control the heat the manual way. I had someone come in to service my furnace and they set it for the week. How do I cancel that, and just have it so I can turn it up when I want,...
From the Operating Manual: _______________Manual Operation for Non-Programmable Thermostats Press the SYSTEM button to select Heat or Cool and use the [Up] or [Down] buttons to adjust the temperature to your desired setting. After selecting your desired settings you can also press the SYSTEM button to select AUTO to allow the thermostat to automatically change between Heat and Cool. _______________________Manual Operation (Bypassing the Program) Programmable Thermostats Press the [Up] or [Down] buttons and adjust the temperature wherever you like. Then press HOLD. This will override the program. The HOLD feature bypasses the program and allows you to adjust the temperature manually, as needed. Whatever temperature you set in HOLD will be maintained 24 hours a day, until you manually change the temperature or press RUN to cancel HOLD and resume the programmed schedule. ____________________________________________________ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Jan 19, 2011 | White Rodgers White-Rodgers 1F85RF-275...
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Thermostat problems
Have you confirmed that the thermostat is programmed correctly?
Did the thermostat ever control the temperature of the house properly?
When you indicate "kick", are you talking about flipping the Auto-On switch back and forth? The Auto-On switch only controls the fan, and no heating or cooling (Auto - fan runs on call for heat or cool, On- fan runs all the time.).
If "kick" means making the heating work, and if you have the same problem for making the cooling work, chances are good you have bad thermostat.
If the problem only occurs with the heating, and cooling works fine, then the problem could be in the controller board of the furnace, assuming you have a more recent (1990's or newer) furnace.
Jan 16, 2009 | Heating & Cooling
Honeywell - cm61ng- Keeps going on and off all night
Instructions on how to turn off your optimum start:-
Turn off ‘Optimum Start’
Step 1 Put the thermostat in the OFF position.
Step 2 Press 3 buttons together (at the same time) which are the INFORMATION BUTTON (i) and PROGRAM BUTTONS 3 & 4.
This will show a code of ICL 1 – now let go of the buttons.
Step 3 Press PROGRAM BUTTON 2.
This will now show a code of 30t 1
Step 4 Press the + BUTTON (on the left of the display), tap through until you reach 15 OP 1
Step 5 With the TEMPERATURE DOWN BUTTON; change the 01 to a FLASHING 0. Confirm the FLASHING 0 with the INFORMATION BUTTON ( i ). The 0 will now be static.
Step 6 Put the Thermostat back in the ‘AUTO’ position.
‘OPTIMUM START’ is now switched off.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Good morning I have a honeywell programable thermostat and when I bought the house there was no instruction booklet. The heat is shutting off at night The furnace guy is coming sometime today and...
Mebnme, is right, manually setting your therm and holding hold, will override any pre-setting program. Also go to honeywell website, order a manual and program your therm yourself, what model do you have?
Dec 06, 2008 | Heating & Cooling
Honeywell Chronotherm III
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Dec 17, 2007 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
