Question about IFB Washing Machines
My Ifb rdw washing machine show the PS error - IFB Washing Machines
  • 414 Answers
SOURCE: IFB washing machine dryer not working
can you supply the enr?
first port of call is the overheat stat, switch off mains remove lid and in the middle top of the unit there should be a metal chamber that houses the dryer heater, somewhere there, you will see a stat that should have a reset button on it, if you press the button and it makes a definate click, it was tripped. There are some reasons for this, you may be stopping the dryer early and not letting it do the last 10mins which is a system cool down, the fan is not operating or slow, the unit is not draining properly (check pump filter) or you are trying to dry more than 2.5kg (half a load).
Good luck.
Posted on Jul 08, 2010
  • 6277 Answers
SOURCE: my ifb washing machine digital
You will need to type into your search engine the '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Feb 13, 2011
caroldon
  • 17129 Answers
SOURCE: hello my ifb washing machine is
First of all the voltage to the motor must be checked when the program is on the wash mode. If absent then the program controller is faulty. However if there is voltage and the motor hums then the capacitor to the motor must be faulty and replaced. If there is no action then the motor can be faulty. Check also the belt , the spindle for free movement.
Posted on Mar 30, 2011
  • 15 Answers
SOURCE: i have ifb elenaa washing machine. my problem is that water can't enter or drain from machine .help
make sure the water is turned on at the faucet handle behind the washer.
Posted on Apr 20, 2012
  • 3 Answers
SOURCE: My ifb machine is around
my machine is the same model i got it from my daughter who is now abroad
the user manual is not there
i want to know how to use the programe knob
Posted on Feb 08, 2013
Ifb washing machine showing DOOR NOT CLOSED
Visit the sites linked here for more details about the error cddes to many brand washing machine, and dish washers.
http://electrotechnician.blogspot.com/
https://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
Aug 10, 2016 | IFB Washing Machines
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
My ifb washing machine is showing dp error
Jul 05, 2014 | Washing Machines
Dp error in ifb
I had the same error shown in my IFB Se?orita SX. I cleaned the dust collection tray at the right bottom of my WM. It had lot of dust and a coin. Not it works fine. May be this caused the DP(differential pressure) error. Whatever. My machine is working good now.
Dec 17, 2013 | Washing Machines
IFB washing machine front load Showing ' Lo' what
Error code LO normally means the filter is blocked. this would be the best place to start. refer to your owners manual for instructions on cleaning this.
Aug 10, 2013 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Washing Machines Logo
Top IFB Washing Machines Experts
Raj Patel
ray gallant
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
