Question about Vacuums
Steam vac F5915100 brushes not spinning. Cleaned n took vac apart.teeth on turbine not turning lubricated now need hel to put back together. Am 75 and slow but need help
  • 1673 Answers
SOURCE: brushes don't spin
Take out the screws from the bottom, there will 2 longer ones, they got into the turbine, turn it upright and take the top cover off. The turbine sits near the front, center, remove the 2 screws on the front of it, remove the hoses, then you can remove the turbine(#23).
Posted on Aug 10, 2008
  • 97 Answers
SOURCE: i have a hoover steam vac f5899-100
if after you cleaned the brushes and still doesn't work. it will have to be the turbine assembly that the brushes fit into.
Posted on Jul 20, 2009
  • 144 Answers
SOURCE: Help. The brushes on my Steam Vac Spin Scrub
If you don't have the user's manual for the machine, here it is:
Check your system for any obstructions that could possibly causing the problem. Also, remove the brushes and see if there's a problem between the brushes and the motor.
Posted on Aug 25, 2009
  • 190 Answers
SOURCE: I have a hoover f5914-900 steam vac.. and I was
The brush block may be removed from the base for rinsing.
Yes, you can CAREFULLY disassemble the brush block assembly by releasing each of three latches that hold each of the clear gear covers to the main block. A small screwdriver is used to GENTLY lift each tab, one at a time. Pay attention to what position the special gear is at that has the drive pin (1/4 inch square drive) for correct reassembly.
Here is the link to the User Manual that shows how to remove the brushes from the base.
Posted on Feb 04, 2010
  • 438 Answers
SOURCE: hoover steam vac all terrain turbine gear assembly
I'd be happy to walk you through this repair. Unfortunately this is a very common problem with the Hoover SteamVacs.
Here's what you'll need to complete this repair:
- Hoover Turbine Assembly For Model F5866-900 Part # 43191001 or 90001354
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to unclip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before tighting the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
That's about it. If you have any trouble with this repair, please don't hesitate to use the Clarification request form here on Fixya. I'm always more then happy to answer any follow up questions that you might have. If this repair was helpful to you, please help other Fixya members with this same problem find my repair by rating it helpful. You can do this by clicking the 4 Thumbs up icons in the right hand corner.
Thank you very much,
Chris J.
Posted on Apr 10, 2010
Testimonial: "Excellent description! Thanks for the great solution and pictures to help!!!!"
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes won't spin
First, please be sure to unplug your Steam Vac and remove both the clean water and the dirty water tank.
There should be a square stem that sticks up in the center of your brush assembly. If this stem is broken you will need to replace the complete brush assembly. If the stem is good; turn your cleaner on it's side and check in the area where the brush assembly goes (with the brush assembly removed). In the center of this area there is a square hole where the stem from the brush assembly goes. The square hole is in the bottom of the turbnie that spins your brushes. Using a large flat blade screw driver (not so large that you'll damage the hole), stick it in to the square hole and try to spin it. It should spin freely, if it is very hard to spin or won't spin at all, your turbine is bad and will need to be replaced.
Hoover part number for brush assembly:48437022
Hoover part number for turbine: 43191008
May 19, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have a hoover steam vac f5899-100 the brushes doesnt spin...everything else works but tha. we took the brushes apart to clean
Jul 20, 2009 | Hoover F5899-910 SteamVac Vacuum
Brushes don't work on my hoover steam vac v2
The bearing on the inside of the turbine is rusted. You will have to take the hood of the unit and unscrew the black piece that has to rub hoses going to it. Then take apart the black turbine. Inside you will find 2 white gears and a small 1/2inch bearing. Use wd40 to uncease the bearing. After this put the take pliers and make sure the metal post will turn. Spray wd40 on everything you see including Hoover for making such ****. After this put put everything back together. Now the best thing to do is get some automotive bearing grease and put a large amount on bearing and and other metal parts. Put everthing back together. Clean any hair off the brushes and you are ready. Now the bad news if your gears are worn you will have to replace the turbine. Go to an internet website and the part number will be 91001019. I know all this because I spent 6 years working for Hoover and they found it cheaper to send our jobs overseas.
Apr 11, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Had infamous extra part once I put my steam cleaner back together
Steve, The o-ring goes inside the turbine assembly on the metal shaft.
Mar 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes don't spin
Aug 10, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Brushes won't spin on hoover steam vac ls
I have the SteamVac Dual and there's a screen on the underside of the unit. It's beneath the brushes and it's red. You have to pull and wiggle it to get it out. With the machine unplugged, lay the unit with the handle on the floor. In the owner's manual ( ) this is shown on page 10 figure 3-2. Clean that screen.
If they still won't spin, then take the brushes out. Again, with the unit on the floor, you simply grab the unit firmly and pull towards you. It's much easier to remove than the screen. I took the brush unit outside and blasted it with the house. You'll have to pull out whatever fur balls are clogging it but eventually you'll see that the brushes spin freely with the water squirting on them. Plug the brush unit back in and - in my case - they started spinning.
Jun 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Steam Vac model: F7425-900
I had the same problem 2 weeks ago.I took apart the turbine and found that there are two bearings that hold the main gear that were rusted fast. I put some 3in1 oil on them and kept on trying to break them free by turning them,it worked great. Just keep putting oil on and turn them. It beats buying a new turbine! Just pay attention on how you took it apart. Its not to complicated. Good luck!
Aug 27, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
