Question about Exercise & Fitness
How do i fix wrong time on a fitbit alta - Exercise & Fitness
2 Suggested Answers
emissionwiz
  • 80417 Answers
SOURCE: I lost my Fitbit Alta tracker about 2 weeks ago , so I brought a new one - Fitbit Alta , I checked my dashboard and no activity noted. I have fully changed my new one I just need help in starting up
Here you go. How to set up and start using Fitbit for iPhone and iPad
Posted on Jul 06, 2017
What do the characters on the Alta represent?
Solved: symbols and their meaning - Fitbit Community
https://community.fitbit.com/t5/Charge-2/symbols-and-their-meaning/td.../1721698
Dec 29, 2016 - 20 posts
Solved: Hi Everyone, As I flip through my watch, I see some symbols that I do not know the meaning of... is there a photo of ... Ionic, One, Charge 2, Alta HR, and Aria 2 ' Windows 10 ' Android Moto G4 .... And what does active minutes mean? What do the symbols on the Fitbit mean?
Jul. 12, 2017
Alta HR faces
Mar. 18, 2017
no limit for text character
Jan. 19, 2017
Can't understand display icons
Apr. 27, 2016
More results from community.fitbit.com
Jun 01, 2018 | The Computers & Internet
Manual for Alta Fitbit How do I set the time and date for my fitbit
You set the date and time from the Fitbit App or Fitbit Connect when you setup or sync the fitness band with the computer/tablet. Open the Fitbit Dashboard and then tap (or click) the Account icon. Enter the Advanced Settings menu and check the Time Zone section. If needed, turn off the Automatic option and manually set the current time zone. The Alta will display the date and time based on the time on your computer/tablet when you synced the devices. See https://help.fitbit.com/articles/en_US/Help_article/1176/?q=set+date+amd+time&l=en_US&fs=Search&pn=2 . This is the "How do I change the time on my Fitbit device" FAQ.
Alta has the manual for the Fitbit on the product support page: https://help.fitbit.com/?p=alta . The direct link to the manual is https://staticcs.fitbit.com/content/assets/help/manuals/manual_alta_en_US.pdf . Additional device help is available at the help page: https://help.fitbit.com/ .
I hope this helps.
May 02, 2018 | Exercise & Fitness
Set clock on fitbit alta
http://www.hotbuzz4u.com/www-fitbit-comsetup-set-up-your-fitbit-device-online/
Jan 12, 2018 | Exercise & Fitness
How do I reset the time on my fitbit alta
Theoretically the Fitbit should keep the time updated though syncing, but there are some things that throw it off. I would try these steps in this order. Check after each step to see if you have the correct time before doing the next step.
1. Re-sync your Alta to your phone/computer
2. Check your settings on your dashboard to make sure you have the correct time zone selected.
3a. If you sync to a phone make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit (in your Bluetooth settings).
3b. If you are syncing to a computer, then try re-syncing your Fitbit. you might need uninstall/reinstall your software and make sure you are running the most recent version.
4. Try removing the Alta in the Fitbit app (should be under device settings) and then reconnecting it.
Hopefully one of those steps will get you on the right time, but if not, try resetting your Alta by doing the following:
  1. Plug in your Alta in a USB (computer, or adapter) as you normally would to charge it. It should begin charging.
  2. Press the button on your charging cable three times within eight seconds, briefly pausing between presses. (The button is on the end of the charging cable).
  3. Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
  4. After you see the logo you can unplug your tracker from the charging cable.
Oct 20, 2017 | Exercise & Fitness
How do I reset the time on my Alta fitbit?
Theoretically the Fitbit should keep the time updated though syncing. I would try these steps in this order.
1. Re-sync your Fitbit to your phone/computer
4. Try removing the device in the Fitbit app (should be under device settings) and then reconnecting it.
Hopefully one of those things will get you on the correct time :)
My Fitbit Alta is showing incorrect time. How can that be changed?
Oct 12, 2017 | Exercise & Fitness
How do I latch my fitbit
Can't get my flex strap fastened. - Fitbit Community
https://community.fitbit.com/t5/Flex/Can-t-get-my-flex-strap-fastened/td.../194515
  1. Cached
  2. Similar
Mar 3, 2014 - I have trouble fastening my Flex, too. Not only is it difficult to line up the holes with the latch, but I somehow can't press hard enough to click the ...
Clasping and switching your Alta wristband - Fitbit Community
https://community.fitbit.com/t5/Alta/Clasping-and-switching-your-Alta.../1239815
  1. Cached
03-14-2016 13:19 - last edited on 04-25-2016 16:54 by ErickFitbit Moderator. Options. Mark as ... How do I clasp my Alta wristband more easily? Before putting ...
Solved: can't fasten band to wrist - Fitbit Community
https://community.fitbit.com/t5/Flex/can-t-fasten-band-to-wrist/td-p/536044
  1. Cached
  2. Similar
Since it wasn't on my wrist, I could see how to align the band to get the clasp to go through both pieces of ... HelenaFitbit ...... I cannot get my fit and to latch at all.
How can I latch the band easily? - Fitbit Community
https://community.fitbit.com/t5/Flex/How-can-I-latch-the-band-easily/td.../98355
  1. Cached
Jan 19, 2014 - Latch is very difficult. Accepted Solution. 0 Votes. Reply · All forum topics · Previous Topic · Next Topic. 1 REPLY. 01-19-2014 20:16. Options.
Anne Corey - I can't attach my Flex to my wrist. Can not... ' Facebook
https://www.facebook.com/fitbit/posts/595334813824040
  1. Cached
  2. Similar
I can't attach my Flex to my wrist. Can not get the little teeth to go ... To see more from Fitbit on Facebook, log in or create an account. Sign UpLog In. Not Now. How do latch my fitbit Google Search
Dec 28, 2016 | Exercise & Fitness
Exercise & Fitness Logo
138 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
