Question about Mgc P700 17" Flat Panel LCD Monitor
Hello shayna hello there i just got a mgc-p700 but i dont have the wires connectors, could i use this monitor with a windows brain?
0 characters
1 Points
Price of mgc pc monitor
it will depend on the specification of the pc that you want to buy.
Aug 12, 2012 | Mgc Computer Monitors
My monitor flickers erradically.
Flickering erratically is usually a sign that the fluorescent tubes that light up the LCD are failing, or the high voltage power controller that drives the tubes is failing. Although these can be replaced at some cost and a great deal of expense, it is usually not worth it with very nice, new & larger displays selling for less than $ 150 (23" HD wide screen moitors) from even the best brands such as Samsung, Planar, LG and Viewsonic.
Jan 11, 2011 | Mgc P700 17" Flat Panel LCD Monitor
How to connect monotor with the peripheric of hp probook 4710s
44963.jpg Connect this connector to LCD Monitor and restart your system, it will detect your monitor by itself if not click to get help from Microsoft.
Hope this helps if so do rate the solution
Good Luck
Jan 05, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
Order of the connectors on the X7G-NAGAVI?
OK, you will have four connectors (each one with pink and white wires), there are two set of the connectors, two are above the transformer, two below the transformer. The monitor uses four lamps, two for the top side of the screen, two for the bottom side of h screen. You can plug either one of the pair of the connector to the top group of the connector, same for the bottom group of the connectors.
May 05, 2010 | Sceptre 17" LCD Monitor
Mgc computer moniter
Reboot your computer.
When it begins to boot, tap the F8 key repeatedly.
When the menu appears, select Enable VGA mode and press enter.
When the system comes up, right click on the desktp, and select Properties.
Click Settings and set the resolution to 800x600 to start with.
Click Apply or OK
Restart your computer.
Here is a link for this:
Out of Range Error
If this solution has been helpful, please take a moment to rate it. Thank you.
Oct 24, 2008 | Mgc P700 17" Flat Panel LCD Monitor
you may have change the pincushion for the monitor.
go to manu>geogetry> and reajust the pincushing, so it is stright on the side.
and you can also adjust the vertical and horizontal to the best fix.
Oct 23, 2008 | Mgc P700 17" Flat Panel LCD Monitor
No video ?
This is a common problem with LCD panels and usually means that you have a defective backlight. Not an expensive repair but not something you could repair.
Jun 22, 2006 | Mgc P700 17" Flat Panel LCD Monitor
Mgc P700 17" Flat Panel LCD Monitor Logo
16 people viewed this question
Top Mgc Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Mgc Computer Monitor Expert? Answer questions, earn points and help others
