Question about Life Fitness Exercise & Fitness
Have a life fitness x8. the resistance is stuck on OFF. I have unplugged, turned on and off, nothing works. Is there any way I can fix this on my own?
I've had it served several times for this issue.
  • Life Fitness Master
  • 6,694 Answers
If you wish to get some details treadmill repair ; check the site linked here. Pull up older posts.
Posted on Dec 16, 2016
How do I lubricate the walking belt on a life touch elliptical cross trainer
as new, they should come with a small pot of oil. if you can get some silicone spray and spray it under the belt, as you hold the belt away with a wooden spoon so as not to damage the belt.
Merry Xmas
Dec 07, 2014 | Life Fitness X8 Basic Elliptical Cross...
Life Fitness X3 does not turn on. So I can't set resistance nor intervals with console. Plug was checked and is fine.
follow this steps and fix it.
God bless you
  • Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
    Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
  • 2
    Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
Sep 30, 2013 | Life Fitness X3 Elliptical Cross-Trainer...
Life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
Apr 04, 2013 | Life Fitness Crosstrainer, 9100, 9500 Rear...
I have Life Fitness X3 elliptical machine, and when I start pedalling/striding the level setting goes to
adjust the magnet, tight the bolts with wren. Test the magnet, with the magnet from refrigerator, for repel and attract, if donot, replace.
The resistance depende of it.
sincerely. God bless you
May 06, 2012 | Life Fitness X3 Elliptical Cross-Trainer...
Treadmill not working
Unplug unit open the motor shroud and inspect all wire connections to see if any rodent activity may have occurred. They could have built a nest inside. If you spot and damage then I suggest you call a qualified servicer to further assess the unit. Call Life Fitness @ 1-800-351-3737.
May 05, 2010 | Life Fitness 9500HR Next Generation...
Stuck Key Error Message on Life Fitness F3
Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
May 03, 2010 | Life Fitness F3 Folding Treadmill with...
T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
Jul 28, 2009 | Life Fitness T3 Treadmill with Advanced...
Fisher & Paykel intuitive code 37
As a serviceman for 18 years I have seen this numerous times.
The fault sounds like the motor control module.. Assuming your test on the pump windings was ok..?
Nov 12, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
A/c blower is not working i change the rsistor but still nothing
if blower does not work, check resister and if good or replaced , first pull motor and spin fan manually, then turn on switch. mine was stuck twice and if you turn on to long with fan stuck it fries resister.
Aug 02, 2008 | 2000 Kia Sportage
Exercise & Fitness Logo
73 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
